Transmission problem/????
Old Sep 17, 2009 | 07:45 PM
88 yellow crx's Avatar
Default Transmission problem/????
I have a gsr hydro trans, with a tilton twin disc, tilton release bearing, tilton 3/4 master cylinder, tilton flow control, avid solid mounts, and a G-force shifter. I installed a quaife and gear speed carbon sychros. The problem im having is when i first drive the car after i start it, it will go into 1st gear with no problem. When i take off and go through the gears then come to a stop and try to put the car into first gear it wont go in, until i let the car sit for a minute then it will go into gear. Was wondering if anyone has experience this problem and what they did to fix it???
Old Sep 17, 2009 | 08:00 PM
SPOOLINmatt's Avatar
Default Re: Transmission problem/????
check hubs for cracks, most likely the brass synchro has worn so bad that its tucking under and getting way out of alignment....its happened to me before.
Old Sep 17, 2009 | 08:43 PM
The sychros are new less than 25 miles on them..
Old Sep 17, 2009 | 09:06 PM
Martian's Avatar
Sounds like the clutch is not fully disengaging.
Old Sep 18, 2009 | 04:51 AM
damn you a have a lot of aftermarket stuff that needs to be checked then...its either clutch not fully letting go or your g force.
Old Sep 18, 2009 | 05:12 AM
Blown90hatcH's Avatar
What happens if you pump the clutch pedal?
Old Sep 18, 2009 | 05:48 AM
I tried pumping the clutch still doesnt help. The only thing that seems to work so far is to let it sit for a minute or so then it will go in. The weird thing is that it will go into any other gear when i come to a stop with no problem at all, just not 1st.. I would like to get this problem fixed cause i want to go to the track this weekend and im going to look like a as****e after i do my burnout waiting to get the car in gear...lol
Old Sep 18, 2009 | 05:50 AM
tofast4uh22's Avatar
just keep the car in first gear while doing the burnout, and then stage while still in first gear. lol sorry i was of no help.
Old Sep 18, 2009 | 05:57 AM
Lol... Def thought about doing that but just worried i wont being able to get the tires hot enough in 1st. Plus if somethings not right i wouldnt want to hurt anything else.
Old Sep 18, 2009 | 07:10 AM
nasteboyii's Avatar
HAVE u tried going to second gear first then to first, when my trans gets worn on all my hondas she does not like goin into first when running. but if u go to second gear then first goes in smooth, not sure why but, been doin for prob like 5-8yrs on all my cars. and it works for me,
hope this may hhelp
dan
Old Sep 18, 2009 | 10:14 AM
Yes i have tried to go into 2nd first but still doesnt go into 1st when trying that either. Does anyone think there is a part in the trans that my be no good causing this problem??
Old Sep 18, 2009 | 10:08 PM
Martian's Avatar
The brass synchro ring might be toast, but I still lean towards it being clutch adjustment. Put the front of the car in the air, have someone start it and put it in first. With the clutch in the tires shouldn't rotate at all. If they do grab one and feel how much force is being applied. Tighten up the clutch and do it again, until the clutch no longer grabs when its supposed to be disengaged.
Old Sep 19, 2009 | 08:07 AM
mike93eh2's Avatar
did you mistakenly put the 1st/2nd hub slider on upside down? ive done that before and thats what what will happen.
Gamblor
Transmission & Drivetrain
Jun 29, 2017 09:09 PM
Gsrsi
Sep 9, 2012 09:59 PM
Radyjr
Mar 2, 2012 10:30 PM
rIceNOodles
Jan 26, 2005 01:01 PM
JunIntegra
Mar 24, 2003 12:47 PM
