Transmission fluid
Old Mar 24, 2010 | 08:40 AM
Birdley42008's Avatar
Default Transmission fluid
Hey I was just getting everything ready for race season and I decided I would try something different for the transmission fluid. I usually use cheap 10w30*** (not 5w30 made a typo) as suggested. What do you guys use in your stock transmissions? I have a stock SOHC ex tranny from a 2000 civic. Thanks I appreciate the advice!
Old Mar 24, 2010 | 09:31 AM
Default Re: Transmission fluid
Thumb'd through some pages and seems people use torco and royal purple fluids. Is there any fluid people use that is easier to find maybe at say walmart?
Old Mar 24, 2010 | 09:51 AM
fukenricen's Avatar
i use gm synchromesh but has to be the modified friction one
Old Mar 24, 2010 | 09:53 AM
kaiba's Avatar
The Honda stuff.
Old Mar 24, 2010 | 11:39 AM
turbologist's Avatar
Torco here...
Old Mar 24, 2010 | 11:41 AM
01DC4's Avatar
Theres a few good threads if you search.
Old Mar 24, 2010 | 12:13 PM
theidealone's Avatar
Honda MTF.
Old Mar 24, 2010 | 01:48 PM
I have been searching but you can imagine the globs of info I need to sift through. Sometimes people change their opinions over time/experience. That is why I am just checking in. People said the Honda MTF was something to stay away from.
Old Mar 24, 2010 | 02:06 PM
narfdanarf's Avatar
been using the GM syncromesh with friction modifiers myself...I like it a lot, but I think I'm going to try the torco stuff this time around for ****'s and giggles.
Old Mar 24, 2010 | 05:58 PM
jdm inc's Avatar
I had a thread asking a similar questions here are some results.
https://honda-tech.com/forums/drag-racing-36/high-hp-guys-what-do-you-use-tranny-fluid-2660132/
Old Mar 24, 2010 | 06:09 PM
Perfect thanks for all the help guys. I know all the options just seeing what is considered the "best"
Old Mar 24, 2010 | 06:38 PM
turbotypeR@SPEC's Avatar
25 Year Member
Honda MTF or 10w30
Old Mar 25, 2010 | 06:56 AM
grand champ's Avatar
Honda MTF!! Ive tried everything. This is the only one that wont wear out synchros. GM syncromesh is ok as well. But i still find the honda superior!
Old Mar 25, 2010 | 07:57 AM
Went with valveline 10w30 seeing as how it is a stock tranny. Cheap and easy! Once I get a LSD im gunna swap over to torco RTF!
Old Mar 25, 2010 | 03:21 PM
h22 civic's Avatar
joe gibbs
Old Mar 25, 2010 | 04:28 PM
c5R's Avatar
c5R
i use libertys fluid in my trans
Old Mar 26, 2010 | 05:25 PM
philacc23's Avatar
TRIAL USER
I just bought a used 97 accord/manual tranny. The 5th gear was grinding very noticeably, and the 3rd gear was grinding every now and then. I just changed the tranny fluid with the new Honda MTF, and all I can say is woooowwww. There are now no more grinds in the gears, and it's shifting smoothly. I thought it was going to take a few hundred miles for it to smooth out, but I'm now a honda mtf believer.
Old Mar 26, 2010 | 07:48 PM
It probably had no fluid in it to begin with. Any proper fluid in that situation would make it not grind.
entityzero
Sep 1, 2006 10:33 AM
sloweredcivic
Sep 21, 2005 08:27 PM
Totalpkg
Nov 15, 2004 11:07 AM
All Motor TypeR 133
Feb 13, 2003 01:00 PM
Pure R Racer
Nov 22, 2001 06:50 PM
