tranny problems
Old Sep 10, 2005 | 08:32 PM
spockeg's Avatar
Default tranny problems
I wanted to know what you big boys are running for trans setup. I have gone throw two transes in the last three months. the first trans i destroyed was my kinda of my fault, was in a hurry to stage and did not preloud the clutch their for blowing up my diff. the second one i'm not sure how i did it. i launched and got wheel hope and about 20ft past the tree my shift linkage dropped it broke right where the shift linkage stabilizer bolts to the trans it completely broke of. if you could tell me your setup or give me suggestions that would be greatly appreciated.
Old Sep 11, 2005 | 08:02 AM
Zubaltec's Avatar
Default Re: tranny problems (spockeg)
I've never seen a trans. break where yours did ( where the shift linkage stabilizer bolts to the trans)
Do you have aftermarket mounts? Cause you need them.
We use a STOCK trans with a good diff (). Either a B16 or a GSR.
John
Old Sep 11, 2005 | 04:03 PM
spockeg's Avatar
Default Re: tranny problems (Zubaltec)
yes, i have AZ race mounts and it was a stock b16 tranny from HMO
Old Sep 11, 2005 | 04:24 PM
Adi Radoncic's Avatar
On Fire!
Do you have all 5 mounts installed on the car, is the car lowered, whats the front end alignment like?
Old Sep 11, 2005 | 04:42 PM
spockeg's Avatar
Default Re: tranny problems (Adi Raaa)
it is in a eg hatch the two mounts in the front are stock and the alignment is ok. and it is stock suspension. i was planing on putting H&Rs with some KYB AJX next but this happened so need to find another trans or case.
Old Sep 11, 2005 | 05:14 PM
boostfeen's Avatar
those stock motor mounts helped cause you to break.
there is def. to much motor movment. hasports are the ****, you should look into getting a set.
Old Sep 11, 2005 | 06:12 PM
spockeg's Avatar
Default Re: tranny problems (boostfeen)
the three main motor mounts are stiff as hell i was talking about the ac bracket and the lower trans mount.
Old Sep 11, 2005 | 08:13 PM
bootlegcivic's Avatar
Fill those mounts with windshield adhesive! Ghetto but works well.
ERKK
Apr 28, 2009 05:31 PM
Its me DUB
Mar 2, 2007 08:42 AM
zephon96
Jul 27, 2005 01:56 PM
E-lude78
Mar 30, 2003 12:04 PM
ricodemus
Sep 12, 2002 11:39 AM
