tranny guru need input
Old May 23, 2015 | 11:42 AM
carbon fiber coupe's Avatar
Default tranny guru need input
I have a gearing question
I have a stock gear set gsr trans
right now on a normal pass (19psi 9200 redline) I am shifting from 3 to 4 at about the 1100ft mark.
what can i change to stay 1-3 for the whole pass? sorry not to big on trannys and gear and what not.
Old May 23, 2015 | 01:06 PM
Turbo-LS's Avatar
Default Re: tranny guru need input
Longer final drive or more power or shorter gearing all together so you get through to the top of 4th gear
Old May 24, 2015 | 01:18 PM
tepid1's Avatar
Tire size plays a large role. Some more info is needed.
Old May 24, 2015 | 11:06 PM
Ron Burgandy's Avatar
You want to stay in 3rd?
Old May 25, 2015 | 02:48 PM
405 whp
24.5/9/13 slick
im shifting so close to the end it seems like its "slowing me down" by shifting then passing through the traps
i have 2 tunes on the car a pump gas and c16 tune i havent ran it on the c16 tune yet to see how it goes
Old May 25, 2015 | 08:46 PM
MR.johnson's Avatar
shorter tire, longer fd, turn the boost up Are all options.
Old May 27, 2015 | 12:15 AM
choadsi's Avatar
1/8 mile? stock gsr on 24.5 you should ride all of 4th out unless you have a FD under a 4.0. I would think you have a ls gear stack with a 4.0 FD but even then you should bang 4th sooner than that. I don't know much about trans but you don't want to use 1-3 for the 1/4 mile because around 1000ft mark is chute popping area and you're still banging gears
Old May 29, 2015 | 01:08 AM
Aquafina's Avatar
You don't want a 3 spd setup. You should cross the line at the top of 4th. Run the B16 3/4. 4.26 FD if needed.
Old May 29, 2015 | 07:24 AM
hardcore97's Avatar
doesnt sound like a gsr trans to me. my setup on a gsr trans and 24" tire puts me shifting into 3rd around 112 mph and thats revving to 9500. at 400 whp you should be trapping in the 120's so i wouldnt think you would be shifting to 3rd that close to the end of the track if you are only around 110 mph
Old May 29, 2015 | 11:41 AM
previous owner told me it was a GSR....
my best pass to date is 121mph.....
obviously without taking it out i would have no way to know for sure what the stack is,
Old May 29, 2015 | 04:33 PM
DA-NINE's Avatar
cruise around and do a log of cruising rpm in each gear. with that you can compare the vss reading and engine rpm to accurately determine your gear ratios.
79malibu
Sep 20, 2015 08:25 PM
casprghst68
Transmission & Drivetrain
Jun 23, 2014 03:46 PM
MoiMotorsports
Aug 3, 2010 04:46 PM
CRXizSLAMM'd
Jul 14, 2004 05:14 PM
RS_91
Aug 27, 2003 07:31 AM
