Traction Issues
Old Sep 20, 2013 | 04:56 PM
  #26
narfdanarf's Avatar
Default Re: Traction Issues
Originally Posted by magik28
The bfg drag radial worked well for me. My experience with them is at P225/45R17 with a 230hp motor +150shot nitrous. Less then your making overall but i liked them. I will say this though. With the bfg at full tire pressure they are no different then a street tire. It wasnt till I lowered air pressure and put some heat to them that they work. I dont believe a highway pull will put the proper heat to them to make them work. But I have no science or numbers to back that just experience at my power level.
yokosuka huh?
Old Sep 20, 2013 | 06:33 PM
  #27
magik28's Avatar
Originally Posted by narfdanarf
yokosuka huh?
Yea i need to update that and my avatar. That baby is now 7 lol. Was stationed when i started my account.
Old Sep 23, 2013 | 02:05 PM
  #28
95eggsr66's Avatar
Im using a 225/50 MT et street and at 28psi in them second gear hooks with 411whp/283wtq. 3rd gear dead hooks
Old Sep 23, 2013 | 05:41 PM
  #29
xbigpitax's Avatar
Originally Posted by Turbo-LS
Bfg radials are garbage don't bother.
How much power u making? Because I make 600hp I got 225-50-15 Bfg drag radials an a lot of supporting traction parts an I hook 60rolls an I gotta throttle the car a little an I hook 40 rolls.... This is also break boosting with no LSD an no boost by gear!
Old Nov 3, 2013 | 08:50 PM
  #30
kculfoelcric's Avatar
Get a set of spare wheels and throw some slicks on them for racing. If that doesn't do it gear Dependant boost will get it done
Old Nov 4, 2013 | 05:41 AM
  #31
92egdxhatch's Avatar
With 350whp I would paint black lines on concrete through third on 225/50 ET streets. The only time my car has ever hooked is at the track on an M&H slick.
Old Nov 4, 2013 | 05:47 AM
  #32
$MIKE$'s Avatar
Originally Posted by AZ_CIVIC
I use the MT ET Streets 225/50/15's and those are pretty bad a@@.
X2 say good bye to traction problems then I upgraded motor and turbo still break loose in 1/2 gear. But when I was at 400 wheel hp they were awesome.
Traction bar and proper alignment are key
Old Nov 4, 2013 | 07:25 AM
  #33
E85B18's Avatar
If you want to hook first or second buy an AWD car, turn the power down or run slicks full time.
Old Nov 5, 2013 | 08:40 PM
  #34
xbigpitax's Avatar
The true trick to it all is very stiff rear suspension, traction bar, and tires after that u need to mess around with different things but u all can figure that out no fun in throwing all the secrets out there lol
Old Nov 6, 2013 | 04:31 AM
  #35
1lowek2007's Avatar
I had no traction bars, no stiff rear suspension, and smaller tire. It hooked ok
SilverPanda
Suspension & Brakes
Sep 4, 2007 01:37 PM
Sinner
Sep 12, 2004 06:00 PM
msmithgsr2131
Feb 16, 2004 08:59 AM
DLB1994
Jan 28, 2003 09:40 PM
KoRE
Oct 17, 2002 08:24 AM
