torqueing the head
Old Feb 9, 2011 | 12:20 PM
  #26
waseem's Avatar
Default Re: torqueing the head
at the moment it aint burning coolant or oil just it leaking in 3 corners were the head meets the block
  #27
Divers's Avatar
Originally Posted by waseem
i had the head skimmed but not the block my tuner didnt mention that to me..
it has high comp pistons what head gasket would i need to use if i have to get the head and block skimmed again bcos i dnt knw how many times it has been skimmed before aswel
After cutting the block, check the piston-2-deck and buy a headgasket accordingly. After everything is cut and measured you'll just have to do the math what size gasket will give you the CR you want.
Old Feb 9, 2011 | 12:25 PM
  #28
Divers's Avatar
Check everything above the leaks. Cam seals, distributor o-ring, vtec solenoid, valve cover, and cam plug. Its probably not a headgasket at all.
Note: What does this have to do with Drag Racing?
Old Feb 9, 2011 | 12:27 PM
  #29
waseem's Avatar
my tuner said he torqued them to 72lbs is that enough? do you think thats the reason for the oil coming out of the corners of the head?
Old Feb 9, 2011 | 01:06 PM
  #30
TDI-North's Avatar
Waseem, are you from the UK?
Old Feb 9, 2011 | 01:12 PM
  #31
sanman000719's Avatar
thats my guess after reading how he is wording things
Old Feb 9, 2011 | 01:31 PM
  #32
96 GSR-T's Avatar
what c/r are you currently at? is it leaking bad out of the 3 corners or just pooled up there a little bit?
Old Feb 9, 2011 | 01:38 PM
  #33
waseem's Avatar
Old Feb 9, 2011 | 03:51 PM
  #34
waseem's Avatar
my car is a drag car is 72lbs enough to torque the head down?
Old Feb 9, 2011 | 10:33 PM
  #35
rudebwoy's Avatar
yes! I and all the engines I've built with ARP studs torque to 70ft lbs.
Old Feb 9, 2011 | 11:06 PM
  #36
ahobbs's Avatar
HELLO,GOOD MORNIN'
be sure your dowel pins are in and the head isnt moving on the headgasket. Moving to tech
edit: nevermind drag car soo....ehhh ill leave it
When i used ARP i always went to 72 but I personally like GE's head studs better
Old Feb 10, 2011 | 02:24 AM
  #37
zakura R's Avatar
guys i need some help i have a b18 drag car 6-800hp what head studs shall i use and how much lbs should i torque it?? head has lifted twice so far some one plz help me
Is ur head deck or ur block cuz if it's dowel pins will be too long And when u torque ur head u will have that problem to
Old Feb 10, 2011 | 10:51 AM
  #38
waseem's Avatar
what do i do then? cut the dowels?
Old Feb 10, 2011 | 11:37 AM
  #39
E85B18's Avatar
Does anyone actually know if there's a limit to how many times you can re-use / re-tourque ARPs? Ive been told many different things...
Old Feb 10, 2011 | 01:47 PM
  #40
DeLucia's Avatar
I'm also reusing my arp headstuds but I cannot get them loose outta the block. I was told to lightly screw them into the block until they stop then leave them there don't tighten them. Is it ok that my studs are currently tight in the block?
Old Feb 10, 2011 | 02:40 PM
  #41
a1320addict's Avatar
Have the head milled and check the block for straightness.
I'm assuming this is on a B-Series..
OEM Honda gasket (if 81-82mm)
Golden Eagle MFG gasket if overbore, as they use OEM gaskets.
Golden Eagle MFG studs to 90 ft/lbs, have never had a problem. Make sure to follow their advised procedure in torquing and 1/2 turn back-off at 50 ft/lbs *3* times, yes it matters.
Old Feb 10, 2011 | 04:12 PM
  #42
harhoosh's Avatar
as i advise you and your crew befor, search for another mechanic and tuner.
i have been running OEM head gaskit, ARP stud and made 900+ whp without any problem and you know my car and my garage .
but, it seems you like to deal with biggener mechanics and dumb tunners to avoid paying more for a good mechanic and tuner.
good luck.
Old Feb 10, 2011 | 04:56 PM
  #43
Topdawgg's Avatar
Originally Posted by Garage 808 Hatch
OEM headgasket, ARPs torqued to 85ft/lbs.
allhonda
Mar 23, 2009 07:05 PM
gonmaro
Jan 29, 2009 12:05 PM
roger93si
Jan 16, 2007 10:12 AM
LsVtakYO
Dec 24, 2005 06:53 PM
Powered By Garrett
Apr 22, 2005 08:33 PM
