tire screws?
Old Nov 14, 2002 | 07:33 PM
paulzy's Avatar
Default tire screws?
are they really needed? HOw easy would it be to spin teh slicks on the rims? Wouldn't the bead be able to stay put?
Do I just drill right into teh bead and screw in?
[Modified by paul_vang, 8:33 PM 11/14/2002]
Old Nov 14, 2002 | 08:23 PM
littlebluecrx's Avatar
Default Re: tire screws? (paul_vang)
Mark your rim, and tire, if it is spinning then you need em. Jason
Old Nov 14, 2002 | 09:28 PM
SEFIxCivic's Avatar
Default Re: tire screws? (littlebluecrx)
when you put screws in your rim does the tire still hold air good? or does it leak? and you need to run tubes?
Old Nov 14, 2002 | 10:03 PM
paulzy's Avatar
Default Re: tire screws? (SEFI8LOxCivic)
I'm guessing you thread them into teh bead of the tire if you don't have tubes
Old Nov 14, 2002 | 10:56 PM
ExospeedAMcrx's Avatar
well theres an advantage and disadvantage to screwing the slicks to the rim.
well advantage is if it is slipping, then it will hold and you may get better traction with it screwed on.
BUT, then expect alot more GRAB, which then transfers the power to the axles and can cause more breakage at that end. some say, they will sacrifice a little tire spin on the rim just so they are not breaking axles all the time.
Old Nov 15, 2002 | 08:05 AM
earl's Avatar
Screw goes into the bead but not thru it. If you go thru, you have a leaker. Most guys don't use tubes.
Old Nov 15, 2002 | 10:32 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: tire screws? (earl)
also use liquid teflon thread sealer on each screw, same thing you use on AN fittings.
tuhboek
Aug 7, 2013 12:13 PM
frokido
Oct 23, 2011 07:29 AM
j0keefe21
10
Jan 16, 2009 07:00 PM
professorman
Jul 15, 2003 07:00 AM
ck279
17
Feb 6, 2002 07:13 AM
