Tiny Hole in revhard manifold? ? ? wtf!
Old May 31, 2003 | 11:22 AM
UltRaH22's Avatar
Default Tiny Hole in revhard manifold? ? ? wtf!
noticed a tiny hole on my manifold yest. . its pretty small. . same size as this ~> # <~ noticed that the leak is causing the car to hit boost quicker. . . i need advice on the best way to fix this. . i cant afford to buy a new one. . anyone else had this problem? ?
Old May 31, 2003 | 12:02 PM
Kazz's Avatar
Default Re: Tiny Hole in revhard manifold? ? ? wtf! (Option2 eg6)
if that happen to me and u say its the size of -> # just put a dot of weld on it .you think its a idea?
Old May 31, 2003 | 01:03 PM
Enzo-Racing's Avatar
Default Re: Tiny Hole in revhard manifold? ? ? wtf! (burp)
you need to weld it.
Old May 31, 2003 | 02:26 PM
Clayton's Avatar
H-T Administrator
25 Year Member
Default Re: Tiny Hole in revhard manifold? ? ? wtf! (Header Tech)
Are the Rev-Hard Manifolds cast? Or tube style? Cause if it's cast you can't just grab a MIG welder and expect to use that.
Clayton
Old May 31, 2003 | 03:43 PM
Suprdave's Avatar
Default Re: Tiny Hole in revhard manifold? ? ? wtf! (Clayton)
Why can't you? Wire brush that **** and drop some weld on it.
Suprdave
Old May 31, 2003 | 04:20 PM
Default Re: Tiny Hole in revhard manifold? ? ? wtf! (Suprdave)
What i would do is clean it very good. then preheat it, then tig weld it.
you shouldn't have a problem.
Old May 31, 2003 | 05:03 PM
Clayton's Avatar
H-T Administrator
25 Year Member
Cast and standard MIG wire won't stick worth a damn. In my experience, if you can find a nickel wire it works a whole lot better. I've welded up more than a few DSM stock turbo manifolds that were cracked, and stadard wire feed or MIG welder just doesn't stick.
Clayton
Old Jun 3, 2003 | 10:13 PM
UltRaH22's Avatar
yea im gonna need to weld it somehow. . hole is like this size ~> O i bet if i told revhard they would tell me to ship it to them and maybe send me a new one? ? but thats downtime i dont have another car to use right now, but i am lookin. . maybe it will be ok to drive on for now, then pick up a new car, send out this manifold, get the new one (hopefully) and ill be ok.
Mikey3000
Welding / Fabrication
Oct 19, 2011 05:37 PM
Columb0
10
Sep 26, 2005 06:35 PM
ThePro
May 20, 2005 08:50 AM
SeanEF
May 26, 2004 09:42 AM
XDEep
Mar 6, 2003 08:56 PM
