Timing for my setup???
Old Feb 17, 2004 | 08:43 AM
SLOAZZ95's Avatar
Default Timing for my setup???
I have a ? about my timing. my set-up: 94 d16z6 block, a6 pistons .20 oversized, zex59300 cam, zex springs, mild port and polish, slight mill of the head, new .1 oversized valves, aem cam gear, 60 mm tbody, port matched intake on t-body side and head side, header, high flow cat, cat-back xhaust. i also have a skunk2 chip in the ecu. what would u set the timing too at the cam gear. any help would be great, i will have the engine back in the car this weekend and want to make sure everything is where it should be when i start it up, i just dont want to mess anything up.
Old Feb 18, 2004 | 05:36 AM
SLOAZZ95's Avatar
Default Re: Timing for my setup??? (SLOAZZ94)
Bump, with all the talk on here about this setup i cant belive that noone has any ideas. come on help a brotha out.
Old Feb 20, 2004 | 03:52 AM
SLOAZZ95's Avatar
BUMP
Old Feb 20, 2004 | 05:39 AM
Clayton's Avatar
H-T Administrator
25 Year Member
No one wants to give you an answer for fear of assisting you in blowing the car up. Set the cam gear at 0 and get it on a dyno and tune it from there.
Clayton
EG-SIXV-TEC
Jun 14, 2013 08:22 PM
brideout
Oct 12, 2009 08:11 AM
turbosol18
Sep 3, 2007 06:36 AM
O16581724 5 2 5
Jul 5, 2006 07:29 AM
EtotheG
Nov 6, 2003 08:40 AM
