Im going to be using an OEM belt with my toda b's.I dont put alot of miles on my motor so i should be fine.I heard the stronger belts are made to last longer that why i figured i should be ok
Don't do it. "B"s are notorious for shredding the teeth off of stock belts. Get the Toda or PE belt, or you will live to regret it
https://honda-tech.com/zerothread?id=295152
Guest
i heard toda's are nooo good. they wear out fast. try the greddy timing belt. my friend at SP engineering says alot of japanese companies use them on their skylines and other cars. not to mention, they're alot cheaper then toda.
