Timing
Old Aug 29, 2012 | 02:56 AM
DraginX's Avatar
Default Timing
I know this is a generalized question and every car is different, but what do you guys typically see for timing after you finish tuning your cars? I'm talking midrange and the top of the power band on turbo cars making power in the 600-800whp range. Please state what fuel you are on also.
Old Aug 29, 2012 | 05:11 AM
surfingsk8r's Avatar
Default Re: Timing
our car has 16 degrees on c16 at 30psi
Old Aug 29, 2012 | 05:48 AM
FRernesto's Avatar
Default Re: Timing
C16 anywhere between 11-17 ign timing depending on where peak tq drops
Old Aug 29, 2012 | 06:19 AM
civic eg's Avatar
Default Re: Timing
I am also wondering the same, but in terms of an al motor car on 114 race gas with 12:1 compression. is 36 to 38 degress way to much?
Old Aug 29, 2012 | 10:22 AM
DraginX's Avatar
Default Re: Timing
Any of you guys add timing down low to help spool your big turbos?
Old Aug 29, 2012 | 10:51 AM
turbociv910's Avatar
Default Re: Timing
this isnt a big block v8.. that seems way to high by about 10 degrees, unless your base timing is off.
Old Aug 29, 2012 | 11:10 AM
civic eg's Avatar
Default Re: Timing
b18c1 motor, stock stroke, 81.5mm bore
Old Aug 29, 2012 | 12:19 PM
badrex38's Avatar
Default Re: Timing
C16 17 degrees 30 psi....advancing ignition doesnt help spool on turbo cars. i advance my ignition under 3000rpms to make up for the lack of instant air so it'll help get the car moving. when it comes to spool up time think of anti lag, we retard our ignition to make boost. if your looking for boost to come in earlier you gonna have to re think your setup (turbo manifold, compressor housing, a.r sizes, IC pipe size and routing, etc)
Old Aug 29, 2012 | 01:25 PM
DraginX's Avatar
Default Re: Timing
Yeah I definately know I need to get a smaller turbo. Just trying to get a better understanding of the tuning side of things. Keep the comments coming guys. It's interesting to see what people are running out there.
Old Aug 29, 2012 | 01:43 PM
2k.civic.si's Avatar
Default Re: Timing
every motor is different....even if you build two identical motors they will not have the exact same tune.
this thread is useless
Old Aug 29, 2012 | 02:18 PM
DraginX's Avatar
Default Re: Timing
Did you even read any of it? It is to get a general idea of where most people are. I'm not looking to take x users timing and throw it at my car and call it a day. Go take your meds they seem to be wearing off...
Old Aug 29, 2012 | 05:26 PM
SPOOLINmatt's Avatar
Default Re: Timing
yea but the difference would be very negligible.
Old Aug 29, 2012 | 06:28 PM
CO_RaceFab's Avatar
Default Re: Timing
^agreed^... I'm curious what's the lowest you guys have taken them... I have gone down to 15* but I don't think it was needed as we weren't picking up much power lb for lb after 35ish psi. At this point the timing mark was at the bottom of the strap.
Old Aug 30, 2012 | 03:38 AM
Topdawgg's Avatar
Default Re: Timing
dont be an idiot, he asked a very basic question and wanted to get an idea of what people are running.
Old Aug 30, 2012 | 04:18 AM
E Town DSM's Avatar
Default Re: Timing
45+ psi 24 degrees 12.0 af vp import
Old Aug 30, 2012 | 05:20 AM
Default Re: Timing
Ricky, if you don't mind me asking what management was that on. I have tuned on import before and I was not that high on timing, I wasn't having det issues but the car just wouldn't make more power with more timing (could be setup related on my part) Don't know it just seems like a lot of timing to me but I have heard that different management systems (read Motec and AEM) will yield different timing values on the same engine. Just curious.
Old Sep 1, 2012 | 04:37 PM
Divers's Avatar
Default Re: Timing
You can have timing issues on hondata cars or any cars with stock distributors. At high rpms the timing you see and timing you are actually getting may be off. If you tune a cat with a distributor and then retune with a management with better triggers and your end timing results will probably be different.
Old Sep 1, 2012 | 04:59 PM
B20luda's Avatar
Default Re: Timing
2 of the same builds wont be exactly the same, but they will be damn close
Old Sep 1, 2012 | 06:34 PM
blackeg's Avatar
Default Re: Timing
yeah i agree. just to know you are in the ballpark range can be priceless for peace of mind. im surprised and happy people are chiming in on this, as some people consider stuff like this "classified."
for what its worth i was at 20 degrees @18 psi making 500hp on vp c12. im using a bone stock ignition with ngk 8's gapped @.018
Old Sep 1, 2012 | 07:01 PM
SwappedTURBOegg's Avatar
Default Re: Timing
start listing ems... AEMv1 e85 35psi 16* never tuned the timing made 750 ran out of everything els first!
Old Sep 2, 2012 | 07:17 AM
Default Re: Timing
Thanks Andy, thats good information that I will keep in mind for sure.
Cheers.
Old Sep 22, 2012 | 10:21 AM
DraginX's Avatar
Default Re: Timing
Exactly why I made this post, if you do alot of searching on timing you don't come up with much. I'm very happy with how many people have chimed in on this.
I would like to see how people are "tuning" in there timing. Far as I can tell some are running step timing, some people get their ve tuned then tune the timing, some do this for each time they raise the boost, etc... Would be nice to hear how people are going about this and their reasoning behind it.
S@nt0s
36
Oct 14, 2005 07:02 PM
CivicRaping
Mar 20, 2005 06:39 PM
P1mpSlap
Jul 29, 2003 10:17 PM
andrewasf77
Nov 14, 2002 10:48 AM
