t56 s2k
Old Apr 10, 2012 | 03:43 PM
ek9+eg6=me's Avatar
Default t56 s2k
hey tryin 2 think of a cheaper option than the getrag, was thinkin t56modified f20 input staft, adapter plate 2 s2k bell housing 2 use s2k twin disk, oem bolts on bell housing, aint really worried where shifter lands, do yall think gear ratios would b close, or if it would take a dump at 10k
Old Apr 11, 2012 | 05:59 AM
scmil95eg's Avatar
Default Re: t56 s2k
How much is the Getrag? How much power will you be putting through this trans?
Old Apr 11, 2012 | 11:57 AM
sportfwddc2's Avatar
Default Re: t56 s2k
sounds like a lot of R and D plus some headaches just to save a little bit of money
Old Apr 11, 2012 | 02:49 PM
dturbocivic's Avatar
Default Re: t56 s2k
you could probably get g force to make you a bellhousing to fit the s2k block, and also fit on the t56 trans, with the proper s2k input shaft. or maybe just get different discs for your clutch to fit the t56 input shaft
Old Apr 11, 2012 | 06:01 PM
ek9+eg6=me's Avatar
Default Re: t56 s2k
the getrag is about 6gs so is the gforce, wolud rather go with the g force if i could get it with s2k the input shaft that way i could us a oem s2k clutch, afi built a adapter for the gforce 4 speed 101 to s2k beelhousing, figured id bother them, if they say no,my best freinds a machinest and im a chertified welder shure we could make it happen
getrag also requires a 2grand clutch and 1grand adapter and mouting bracets and shifter, so your now up to 9 grand
other options is a rossler racing turbo 400 aint seen many adapters out yet, except bmcs but i dont really think theres is out 2 the public, would do this if i could get the adaper kit and torq converter resonable
Old Apr 12, 2012 | 06:56 AM
fmfkid250's Avatar
Default Re: t56 s2k
When Supra guys talked about a cheaper options for the supra. they looked into the T56 and from what they said t56's dont like high rpms. I personally have 0% experance with that trans but thought I would share what I seen before!
Seems like its hard to beat the getrag for $5500 is kinda like buying a fully "built" tranny?
Old Apr 12, 2012 | 07:10 AM
redboost10's Avatar
Default Re: t56 s2k
t56 sucks for anything higher than 8k.
the adapter plates available are way overpriced for what they are, just make your own. i wouldnt let the input shaft make your decision as well.
Old Apr 12, 2012 | 11:48 AM
scmil95eg's Avatar
Default Re: t56 s2k
Quaife makes a sequential 6-speed for the S2000 (that includes a S2K-specific bellhousing) but you'll certainly be in 5-figure $ territory going that route.
Old Apr 12, 2012 | 04:07 PM
ek9+eg6=me's Avatar
Default Re: t56 s2k
i heard the quaifes are garbage after 600hp
Old Jun 3, 2012 | 11:27 PM
bobbyspeed440's Avatar
Default Re: t56 s2k
Well there is a t56 that is great gearing for a s2000 but u will need to run 4.56 rear end gear and I am haveing a custom bell made also and the trans are **** after 8000rpm so u just have it face plated and u are good to go to what ever rpm u want I have done all the reaurch and when the shop is done with nu bell he will start building them for outer s2000 guys in the hole set up from cost.of.trans to bell to clutch and faceplateing I'm looking at 4500 not bad since a good supra trans its self goes for that its also a lot cheaper and easyer to. work on then a supra trans so if any 1 has any questions email me at bobbyrandolph440@gmail.com or text me at 4237164056 I just wanted to be deffrint
Old Jun 4, 2012 | 12:09 AM
Boosted_01 R's Avatar
Default Re: t56 s2k
Go with the V160 and never look back... there is conversion kits out there for the S2K
Old Jun 4, 2012 | 02:33 AM
Honda_Mad's Avatar
Default Re: t56 s2k
Another option to look at is the BMW e36 M3, e46 M3 and E39 M5 gearboxes. They strong, cheap and can handle the hi rpm
Old Jun 4, 2012 | 02:41 AM
gettin it's Avatar
Default Re: t56 s2k
Look at the full blown kits. Using a v160 trans from a supra.
Old Jun 4, 2012 | 06:09 AM
ScorpioMk's Avatar
Default Re: t56 s2k
the v160/161 is the getrag trans, the trans he is trying to avoid using.
I got mazworx to make me a plate to z33 and competition made me a custom twin disc. 500 shipped for adapter and hardware, 1800 shipped for twin disc and I paid 650? for my 05 trans. I dont know if it will work well or not yet but the car will run within a couple months hopefully.
Old Jun 4, 2012 | 06:37 AM
roadracer4life's Avatar
Default Re: t56 s2k
good call on the z33 trans.. they are very strong and might be a very cheap alternative to the v160 trans..
let us know how this guy holds up..
-sam
Old Jun 4, 2012 | 10:33 AM
Justin Olson's Avatar
Default Re: t56 s2k
Also might want to look at the E46 M3 transmission. It's a getrag and nearly as strong as the V160. There is a good number of 1000hp M3's rolling around my neck of the woods.
Old Jun 4, 2012 | 04:56 PM
turbociv910's Avatar
Default Re: t56 s2k
z33 trans are garbage, just like all nissan transmissions. They dont shift near as well/fast as any v160. But are cheap and plentiful.
Im bias from nissan because ive had to replace many transmissions in z33s with less than 600whp. third gear just breaks easily.
Old Jun 5, 2012 | 03:37 PM
ek9+eg6=me's Avatar
Default Re: t56 s2k
glad 2 c this threads still going, not saying the getrag aint a good trans, just there has got 2 b more options out there not explored yet
Old Jun 5, 2012 | 03:54 PM
Kings Performance's Avatar
Default Re: t56 s2k
Don't cut corners and go with a Toyota V160! You wont regret it...
If you go with the T56 you will have to worry about: fitment, midplate, clutch kit, gear ratios, mounts, shifter position inside the car, bellhousing, etc...
After doing all that you will be way over the 2JZ V160 tranny swap.
I've used them all:
-PPG Dog Box
-PAR gear sets
-Stock cryo
And now V160
Best option!
Fernando @ Kings Performance
Old Jun 6, 2012 | 09:04 PM
hybrdthry911's Avatar
Default Re: t56 s2k
You are blessed to have the v160 as an option. It is an end all solution. Stronger(and not much more money said and done) than most built straight cut dogboxes available, with a much better history of staying together on 1000+hp cars.
Old Jun 8, 2012 | 06:54 AM
Default Re: t56 s2k
Kings I'm doing the t56 my self have done all the leg work and resurch on this swap I'm still 8weeks or so from haveing it in my car but I found a t56 with great stoke ratio and is 29" to center of shifter also haveing full scater sheild bellhouseing made will use stock size fly wheel clutch and starter and will hold all the rpm you want I hope it comes to be the alternate for the v160
Old Jun 8, 2012 | 04:43 PM
ScorpioMk's Avatar
Default Re: t56 s2k
You ever think about face plating the t56? I would love to pick up a second z33 box and have it done for 2/3/4.
http://www.libertysgears.com/faceplate-proshift.htm
Old Jun 9, 2012 | 05:37 PM
Default Re: t56 s2k
Yep they are faceplateing it for me
Old Aug 27, 2012 | 02:39 PM
ek9+eg6=me's Avatar
Default Re: t56 s2k
any updates yet, master shift now offers a sequential shift kit now
Old Sep 21, 2012 | 07:44 AM
Default Re: t56 s2k
No my t56 swap is on back burner till Dec when I get a break from school I hope to get it all done in the 5 weeks I'm off
