Swapping modified heads??
Old Jan 26, 2008 | 04:51 PM
fourdoorturbo's Avatar
Default Swapping modified heads??
Has anyone ever used a head that has been drilled to half inch holes for over sized head studs, but used a stock block that is not drilled for over sized holes. Would the head bolt up ok with enough surface area around the washer and nut? Do you think there ever could be any issues?
Old Jan 26, 2008 | 05:25 PM
AllMotorMark's Avatar
Default Re: Swapping modified heads?? (fourdoorturbo)
i am pretty sure that won't work, but i can't say from any experience,
Old Jan 27, 2008 | 06:42 AM
Adriano's Avatar
Default Re: Swapping modified heads?? (AllMotorMark)
1/2 equals 13mm. The stock headstuds are 12mm. I dont think that the 1mm difference will cause a problem.
Adriano
Old Jan 27, 2008 | 07:53 AM
SpeedDreamz.com's Avatar
is it a turbo motor? As long as you still have it on the dowels then it should be ok but what do I know.
Old Jan 27, 2008 | 09:17 AM
Default Re: Swapping modified heads?? (SpeedDreamz.com)
its for an all motor setup not to crazy mostly street car no more then 12:1
Old Jan 27, 2008 | 04:15 PM
Jared's Avatar
depends on how the dowels were drilled in the head
sanman000719
Jan 22, 2011 04:59 PM
natzimus
Apr 27, 2006 06:04 AM
iamhollywood[BRS]
Oct 30, 2003 08:50 AM
kamira
Jun 30, 2002 01:17 PM
