suspension setting for the track?
Old Jul 17, 2002 | 10:34 PM
strils's Avatar
Default suspension setting for the track?
i got my neuspeed sports in and i should have my koni yellows before i go to the track again. what settings do you guys run on the shocks?
Old Jul 18, 2002 | 03:20 AM
Black SVT's Avatar
Default Re: suspension setting for the track? (strils)
Play around and see what happens, but stiffer in the rear is going to be better to keep weight transfer to a minimum.
Old Jul 18, 2002 | 06:15 AM
bigblockEG's Avatar
I would start out by makig the rears as stiff as possible and front as soft as possible. Then with each pass adjust from there. You should only have to play with the fronts because you should always have the rears as stiff as can be when drag racing. Depending on what tires you are going to run matters too. If you are running a slick with low pressure, then you dont have to go all the way soft with the front shocks because the slick will absorb some of the energies. But, the hard tire will not absord any energy ther shocfk to absorb the energy, and thus requiring a softer setting. ** I have had good luck woth the skunk2 drag springs for the rear, if you drag often they may be worth a shot**
CRX_Phantom1
Oct 18, 2005 04:27 AM
Luke J
Suspension & Brakes
49
Feb 2, 2005 08:40 PM
hybridEj6
Jan 16, 2004 12:09 AM
zcpowereddx
Oct 23, 2002 04:52 AM
neket live
Oct 4, 2002 11:23 PM
