Suspension help
Old Jul 21, 2009 | 05:30 AM
MkIIRoc's Avatar
Default Suspension help
I've done some searching and found some good info already but I wanted to see if I could get some help with my specific setup.
Here's the background...
VW Scirocco
1590lbs ready to race
180whp engine
22" M&H's
currently 500lb/in front springs with Koni yellows
Tubular control arms with aurora rod ends
On launch, the rear end doesn't squat at all. The front end lifts alot, and stays up the whole time I'm on the gas. I'll put a video up in a bit, but I would say it lifts about 6-7" or so. It cuts 1.60-1.65 60 foots though.
I'm debating running some lower rate springs in the front with limiting straps to keep the front end down. What spring rate would you guys reccomend for a car this light that doesn't have a whole lot of hp? I was going to try 300-350lb/in. Car was running 12.3's 100lbs ago, so I'm doing all I can to get it in the 11's with an A/M 8 valve engine.
Thanks for any help!
Old Jul 21, 2009 | 06:11 AM
1992Si's Avatar
Default Re: Suspension help
Have you talked to Joey at Progress, he's local to you and may be able to point you in the right direction towards someone that can help.
It's worth a shot and the call is free.
Old Jul 21, 2009 | 07:37 AM
MkIIRoc's Avatar
Thanks, worth a shot. Do you have a website? I did a quick search and couldn't find anything.
Here's a video from the last time it was out. It lifts really bad in first and second, not as bad in third, and flattens out in fourth.
http://www.youtube.com/watch?v=KhhhDfdqM9Q
Alot of the vw guys run 300-375 lb springs in the front, but my car is pretty light. Wasn't sure if I should stay on the lower end of that range.
EJ1B18c
12
Jan 8, 2010 02:55 PM
BoltonGSR
Suspension & Brakes
23
Oct 18, 2008 07:11 AM
Manny_Fresh
Nov 22, 2004 02:45 PM
Warren
16
Dec 12, 2001 08:51 AM
