Supertech valves
Old Jul 16, 2011 | 05:38 PM
TwoKSiR's Avatar
Default Supertech valves
I know this is off topic, but I need to order 4 supertech valves asap. Is there a dealer that lists them individually that I can order from today or stocks them individually? Or do I need to get them from supertech?
Thanks,
Chas
Old Jul 16, 2011 | 07:14 PM
h22apwrd95's Avatar
Default Re: Supertech valves
Did you check with Race Engineering?
Old Jul 16, 2011 | 07:16 PM
cibao2ner's Avatar
ipgparts.com his a seller here ht also...
Old Jul 16, 2011 | 07:41 PM
Hyper16-Johnny's Avatar
Laskey Racing, RS Machines and Import Power House sell them individually.
Old Jul 16, 2011 | 07:47 PM
harhoosh's Avatar
Contact Mike @ laskey racing.
Old Jul 16, 2011 | 09:54 PM
tagperformance's Avatar
I'd stay away from them completely till they have solved the breaking issues.
Old Jul 16, 2011 | 11:21 PM
gringotegra's Avatar
lulz
Old Jul 17, 2011 | 04:42 AM
Dynamic Performance Racing's Avatar
Sorry to hear that you've had bad experiences with them.
We have used them on our race cars, recommend them to customers and currently in our daily driven, pump gas, stock sleeve 10 sec car.
Please contact the respective dealers up top for the individual valve.
Old Jul 17, 2011 | 06:20 AM
The Show Stopper's Avatar
We also carry them in stock & can be purchased individually
Old Jul 18, 2011 | 05:13 AM
90blackcrx's Avatar
Ill toss our name in as well, we have them, most in stock an ship in 1 to 2 days
Old Jul 18, 2011 | 05:35 AM
Topdawgg's Avatar
lol, some people have issues with every type of valve out there...
Old Jul 18, 2011 | 10:26 AM
I guess it's just a coincidence that numerous people on the board had the exact same problem where valves were breaking at the stem and yes people have been using them for sometime now but this has happened recently from like a new batch of valves. The valves were brand new and were installed a day before the race and failed.
Old Jul 18, 2011 | 02:10 PM
MrParks's Avatar
dont always assume its the mfg of the valves, alot of times other mechanical parts can break valves off the stem. take it like a grain of salt. we have seen all valves break.
supertech has been nothing but successful in reliability and performance for over 8 years ive been using them.
we have used everything from rev, si, ferrea, del west, to supertech. we have not seen a reliability issue with all of them. they are work great, imo the machinist is usually are at fault.
you and your machinist have to be very methodical about tolerances and clearances. most cams and rocker profiles or lma dont even fit the bill but what usually breaks first is the valve.
Old Jul 18, 2011 | 06:13 PM
90blackcrx's Avatar
Have not had an issue yet ( knock on wood ) , we have also seen some supertech valves kiss each other or the piston and bend, none have broke. Pulled a head today and four valves kissed the piston but didn't break.
Old Jul 18, 2011 | 07:27 PM
MrParks's Avatar
that would deffinately be a mechanical clearance issue. lol
correct me if im wrong. most of which breakage happens are when things are not set up properly.
v2v, v2p, spring pressure, installed spring height, valve stem clearance, valve stem installed height, spring seat, valve tip height to rocker, rocker lash, cam profile to piston design, even piston rocking in the bore can cause and issue. there is a whole lot of stuff going on in the cyl head most of which all moving parts are associated with in a engine. not to mention moving at over 11,000rpms and sound harmonics play a role. its crazy what you cant see. dont ever assume your **** is fine or close.... if you hear those words from your machinist you better double check your ****. its gotta be perfect.
lubricants also play a major factor in valve longevity
Old Jul 19, 2011 | 06:25 AM
90blackcrx's Avatar
Probably has something to do with that piston being stuck in the very top postion, motor spun a bearing and all 3 pistons are in the normal postion, yet that one is all that way up.
Old Jul 30, 2011 | 09:31 AM
Clayton's Avatar
H-T Administrator
25 Year Member
Please don't post WTB thread in the regular forum. There are sections for this in the classifieds.
Sadao
K Series
Mar 27, 2015 12:16 PM
slammed ej8
May 8, 2009 02:12 PM
Boostage
Sep 17, 2005 10:36 PM
ShortbusEK
Jan 13, 2003 09:52 AM
red91g2
Dec 15, 2002 07:59 PM
