Stock axle Problems!!!!!! Please Help
Old Aug 3, 2006 | 07:07 PM
jpenman50's Avatar
Default Stock axle Problems!!!!!! Please Help
I don't understand why I am breaking stock axles all the time... What should I do?
Old Aug 3, 2006 | 07:13 PM
adrenalinjunkie's Avatar
Default Re: Stock axle Problems!!!!!! Please Help (jpenman50)
Why don't you step up and buy some Mark Williams axles?I think you know it costs some big bucks but damn if you want to win and be consistant thats what its going to take.
Old Aug 3, 2006 | 07:16 PM
tony1's Avatar
You're probably not pre loading right on the line. Hold your ebrake up and let the clutch out until it starts to grab. Then lock the ebrake and let the clutch out more...just don't redlight!
Old Aug 3, 2006 | 07:19 PM
jpenman50's Avatar
Default Re: Stock axle Problems!!!!!! Please Help (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">You're probably not pre loading right on the line. Hold your ebrake up and let the clutch out until it starts to grab. Then lock the ebrake and let the clutch out more...just don't redlight! </TD></TR></TABLE>
I Have tried this but everytime I do so the axle pops out of the trans... Maybe I should contact honda about these dahm thing not working.... How much power can I make on them
Old Aug 3, 2006 | 07:21 PM
Just curious Tony on the car you race do you run stock axles.I guess you probably do but not sure.
Old Aug 3, 2006 | 07:26 PM
tony1's Avatar
If the axle is popping out then that means the ebrake is up too hard. Try using the foot brake instead of the e brake, it'll hold the front brakes and help keep the axle from popping out.
Old Aug 3, 2006 | 07:28 PM
jpenman50's Avatar
Just curoius, but what is an "e brake"?
Old Aug 3, 2006 | 07:30 PM
tony1's Avatar
It's a brake that's there for emergency situations, it's usually on a handle in the middle of the car. It's not hydraulic, so if the hydraulic brake system goes out, the "e brake" can still be used to stop the car. Does that make sense?
C'mon man!
Old Aug 3, 2006 | 07:31 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: Stock axle Problems!!!!!! Please Help (adrenalinjunkie)
I can't believe you guys are taking this seriously.
Old Aug 3, 2006 | 07:36 PM
jpenman50's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">It's a brake that's there for emergency situations, it's usually on a handle in the middle of the car. It's not hydraulic, so if the hydraulic brake system goes out, the "e brake" can still be used to stop the car. Does that make sense?</TD></TR></TABLE>
so serious.. I like it...
Old Aug 3, 2006 | 07:38 PM
tony1's Avatar
I just can't believe you have a 9 sec. car and don't know what an e-brake is...
Old Aug 3, 2006 | 07:43 PM
jpenman50's Avatar
I think my 9 sec passes have all been flukes....
Old Aug 3, 2006 | 07:44 PM
Arturbo's Avatar
Better than steak
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jpenman50 &raquo;</TD></TR><TR><TD CLASS="quote">I think my 9 sec passes have all been flukes.... </TD></TR></TABLE>
just like your dynos.
Old Aug 3, 2006 | 07:49 PM
jpenman50's Avatar
Default Re: Stock axle Problems!!!!!! Please Help (Arturbo)
[QUOTE=Arturbo]
[/QUOTE
What is all your guys problem? I run 10's all day with that power...
Old Aug 4, 2006 | 01:09 AM
Tyler H's Avatar
What does your roll cage look like? Depending on the way your D-Bars are run, it can put extra stress on the axles. Or it could be your engine management. Have you tried an AEM EMS???
Old Aug 4, 2006 | 06:06 AM
miamidamian's Avatar
you can also JB weld the axles to the intermediate and to the outer hubs.....helps reduce axle pop outs..
its probably because you arent double clutching when you should!
Old Aug 4, 2006 | 06:29 AM
Turbocivic94's Avatar
Default Re: Stock axle Problems!!!!!! Please Help (miamidamian)
Its a easy fix
Just go buy obx diff and axle will never pop out
Old Aug 4, 2006 | 07:27 AM
Pro-Am 1934's Avatar
Default Re: Stock axle Problems!!!!!! Please Help (Tyler H)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyler H &raquo;</TD></TR><TR><TD CLASS="quote">What does your roll cage look like? Depending on the way your D-Bars are run, it can put extra stress on the axles. Or it could be your engine management. Have you tried an AEM EMS???</TD></TR></TABLE>
You always gotta throw that plug in there don't you . . . .
jxhxb
Oct 8, 2009 09:55 PM
00-501itrspec
Feb 6, 2008 06:39 AM
Markb16a
14
Oct 16, 2005 08:22 PM
importdude2000
Oct 15, 2004 09:42 AM
teamnvisible
Mar 25, 2002 04:00 PM
