staging brake
Old Sep 16, 2008 | 06:51 PM
EG BEAST's Avatar
Default staging brake
ok so my race car will still be driven on the street rarely. and im wondering if there is a way to close the flow going from the stock master cyc going to the rear brakes? therefore allowing me to use a staging brake on the track but change it when im on the street. THANKS
Old Sep 16, 2008 | 07:15 PM
JDMBrian's Avatar
I know a lot of domestic guys use a Line Lock for that purpose, but I have yet to see one used on a import. Maybe that's a option for you??
Old Sep 16, 2008 | 07:37 PM
Boostfed86's Avatar
Default Re: (JDMBrian)
I have been wondering nearly the same question. Does anybody use a linelock solenoid for launch control? I've been pondering this for some time now...
Old Sep 16, 2008 | 07:59 PM
fast is fun's Avatar
Default Re: (Boostfed86)
yes
Old Sep 16, 2008 | 09:05 PM
toubaby2's Avatar
Plenty of imports use them.
Old Sep 16, 2008 | 11:16 PM
ninesecrx's Avatar
Default Re: (rota92)
They have units that you just plumb in line with the rears. The brakes work like normal and fluid goes through them. When you pull the handle back, it then just works the rear brakes. Nothing needed to fab up, just buy the correct one.
Old Sep 16, 2008 | 11:37 PM
LA_HONDAS's Avatar
Default Re: (ninesecrx)
do you have a link
Old Sep 17, 2008 | 02:47 AM
1992Si's Avatar
Like Mike said, I believe you just buy 2 line locks and plumb them to each rear brake and wire them to the same switch.
Call NRG Tech and they can take care of you.
Or Mike Laskey at, well just read his post.
Old Sep 17, 2008 | 01:48 PM
ALL IMPORT's Avatar
Default Re: (1992Si)
2 line locks? 1 should do the job
Old Sep 17, 2008 | 02:39 PM
speeddave's Avatar
in that first link you posted rota92 under cnc brakes is the inline hand brake. i think thats the one Mike is talking about.
seems easier to use than ebrake for burnout/staging...
Old Sep 17, 2008 | 06:27 PM
srmofo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 &raquo;</TD></TR><TR><TD CLASS="quote">Yup, the inline setup can be hooked up to line locks as well while retaining a normal braking system for your drive home.
Brian (cluelessmale) has a nice pic somewhere of his setup, works great!
I run a single line lock to the rears from a non-inline staging brake since the car will not have any rear brakes besides from the staging brake.</TD></TR></TABLE>Whats that like slowing down from 145 with NO rear brakes Im sure you have a chute but still,damn
Old Sep 17, 2008 | 06:35 PM
SPOOLINmatt's Avatar
Default Re: (srmofo)
your car already has a staging brake, in between the seats.
I always use mine and it works great, preload with it, drag the brakes to the second stage bulb, drop and go. Pretty simple i thought, and cheap!
Old Sep 17, 2008 | 07:15 PM
Garage 808 Hatch's Avatar
i'm setup the same way. brake pedal only uses the front brakes. then the rears are hooked to a CNC staging brake with its own reservoir.
Old Sep 17, 2008 | 08:17 PM
EG BEAST's Avatar
thanks guys.
Old Sep 18, 2008 | 04:25 AM
Last year I had a normal setup, but the HR car will go 180+ with no brakes, all chute lol
Gonna take some getting used to, that's for sure! </TD></TR></TABLE>
no brakes all chute??
Old Sep 18, 2008 | 03:33 PM
G2K's Avatar
G2K
Default Re: (SPOOLINmatt)
I think he means no brakes on the rear. The chute works good, but most peope still use alittle pressure on the front brakes.
Old Oct 2, 2008 | 02:46 PM
vectorsolid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 &raquo;</TD></TR><TR><TD CLASS="quote">He's asking if there is an inline unit. Which there is, CNC makes one.
http://secure.chassisshop.com/Default.aspx
http://www.kenskustomchassis.com/
Or, support the guys that support us;
http://nrgtechracing.com/
Tom can make you something up, or the guys can get something to work for ya. Call NRG up and let them know what ya need </TD></TR></TABLE>
I'm in the same boat looking.
A direct link to the part would help a lot. It would seem I am gameless at finding those items on those sites.
Here's a direct link to a staging brake.
http://www.cncbrakes.com/hsb.a...eries
And a minor how-to:
http://www.drifting.com/forums...16787
Old Oct 2, 2008 | 04:29 PM
But since you have a CNC PN, it's just ordering that is missing.</TD></TR></TABLE>
On my blue hatch (13.8 sec car) I didn't even know my rear brakes were shot, and didn't work, until I started trying to use the e-brake to stage. I was driving it for almost a year, and thought the brakes kicked ***... all I had was fronts.
Modified by vectorsolid at 5:35 PM 10/2/2008
Old Oct 2, 2008 | 04:39 PM
Default Re: (vectorsolid)
Found this image at the chassis shop. Is this like the opposite of what we need? For whatever reason, I'm not wrapping around this accurately.
Old Oct 3, 2008 | 04:36 AM
Matt2352's Avatar
vector,
That diagram is for a RWD car so you just need to change the label from front brakes to rear brakes and vise versa.
K20EF8Dx
Jun 17, 2013 05:04 PM
allmotorh2b
Feb 27, 2012 08:03 AM
kndaqikEG
May 14, 2005 10:56 AM
snowseeker
Nov 9, 2004 04:32 PM
ActiveAero
14
Sep 30, 2002 02:10 PM
