spinwerks on ITR?
Old May 12, 2011 | 04:47 AM
ekcoupeh22's Avatar
Default spinwerks on ITR?
hey i want to get a set of spinwerks front and rear for my itr but sombody mentioned that i will need wheel spacers for the front does anybody know what size spacer and what offset i should run on a 13x8?
Old May 12, 2011 | 07:38 AM
ekcoupeh22's Avatar
Default Re: spinwerks on ITR?
Bump nobody?
Old May 12, 2011 | 08:12 AM
96 GSR-T's Avatar
13" Wheels barely clear my GSR Brakes, pretty sure ITR's have to run 15" Wheels...
Old May 12, 2011 | 08:32 AM
ExospeedAMcrx's Avatar
dude, it was 3 hrs since you posted last. no need to bump.
Since I'm in the helping mood, I'll answer your question. NO the 13x8 wont clear ITR brakes. A spacer wont help either. The overall diameter of the caliper/rotor setup is bigger than the inside diameter of a 13" wheel barrel. You need to run a 15" wheel with an ITR brake setup.
Old May 12, 2011 | 09:47 AM
Poootie's Avatar
bumpppp!!
The guy above can get you set with wheels for your application. Spinworks also makes a 15" wheel to fit 5-lug also (buddy of mine just ordered a set and they fit well)
Old May 12, 2011 | 08:13 PM
ekcoupeh22's Avatar
Ok I went onto exospeed websit because a friend of mine has the rims from there bit I didn't see any 5 lug rims I don't know if I was looking in the wrong area but if you can point me to the right spot I would appreciate it
Old May 12, 2011 | 09:00 PM
Our STAR5 3 piece forged wheels can be made in any widths from 7 to 14" in 1" increments. We can also custom make it on whatever backspace you need it to be. I can help you with what will work with your car.
The STAR5 is our 5x114 or 5x100 lug pattern wheel. If you have further questions, just email at sales@exospeed.com and we can help you as much as we can.
Old May 13, 2011 | 04:48 AM
sheepey's Avatar
Exospeed wheels are well worth the money! One badass wheel
Old May 13, 2011 | 03:07 PM
Ineed$'s Avatar
Absolutely correct unless you run a custom brake setup, I had my ITR 5lug civic ready and able to run 13" diameter wheels. I had my type r rotors machined down to the same exact diameter size as a GSR/LS, I also ran a set of GSR/LS calipers with washers on both inside and outside on the calipers so the pads wouldn't rub on the rotors, clearance is just right for this setup and no brake performance is lost. I ran a set of Bogart flystars with wheel spacers with no issues at all.
Here's an old shot of Nyce1's old civic with the same exact setup that I speak of
Old May 13, 2011 | 03:09 PM
Ineed$'s Avatar
Also Wil is the man to see for drag wheels, If your in the market for drag wheels then EXOSPEED is who you need to see.
BringIT
Nov 28, 2006 04:39 AM
BsmoothR
Jul 22, 2006 03:18 PM
HybridKOOP
Nov 28, 2005 02:06 PM
2.2XDreams
Jun 11, 2004 11:22 PM
95dc2
27
Feb 28, 2004 06:10 AM
