Solid Mounts OR NOT!!!!
Old Dec 15, 2008 | 04:09 AM
JBLAZE622's Avatar
Default Solid Mounts OR NOT!!!!
i have the hasports billet mounts on my car now and was thinking about sending them back and having them made into solid mounts now i've heard good and bad when it comes to solid mounts but i was wondering what everyone else has 2 say about them my car was making 745 whp and will be making a little more next year with a re-tune @ more boost
Old Dec 15, 2008 | 04:25 AM
Clayton's Avatar
H-T Administrator
25 Year Member
What do you do with the car? DD? or track only?
Old Dec 15, 2008 | 04:59 AM
1992Si's Avatar
I'm a believer of solid mounts. As specialy the two lower ones, IMO you don't want the bottom of the block moving during shifting.
You can fab your own lower mounts out of 1/4" steel plate. I had a L bracket made for the tranny mount to the traction bar mount. Then had a straight 1/4 plate on the drivers side.
Old Dec 15, 2008 | 06:35 AM
underpressure02's Avatar
I have been running solid motor mounts in my car for year. I use to daily drive the car. There is no problem with them. I made solids for my all motor daily driver and been driving it for 3 years. It is not as bad as you think
Old Dec 15, 2008 | 06:40 AM
Turbo-charged's Avatar
a car with that much power should have solid mounts for sure.
some cars are worse than others when using solid mounts for a daily driven set up.
on my old DD integra i had a solid rear mount and the other mounts were stock, worked good. i had solid upper mounts in it for about 30 min. then i took them out as it made the car horrible to drive.
Old Dec 15, 2008 | 06:47 AM
1KWHP1G's Avatar
I have solid mounts in my 1G Talon AWD.The front and rear motor mounts are solid steel and the side and trans mount are poly.I used to have 3 solid mounts in it.It rattled your teeth loose.The side mounts are not as important as the front and back.I've even seen guys just use one solid mount.
Old Dec 15, 2008 | 04:22 PM
JBLAZE622's Avatar
the car is a drag car so i guess i'm gonna go with the solid mounts its $100 to have hasport make the mounts i already have into solid ones thanks for the input
Old Dec 15, 2008 | 05:37 PM
cluelessmale's Avatar
I just made my own solid mounts, cost me $20 in supplies
cutting torch, mig welder, cut off wheel and a getto drill press
Old Dec 15, 2008 | 05:43 PM
rota92
Guest
Posts: n/a
Haha Chad was telling me about that this weekend. I hope you got pics of the process! lol
Old Dec 15, 2008 | 05:50 PM
mHeant2B's Avatar
solids ftw
Old Dec 16, 2008 | 02:41 AM
1992Si's Avatar
It's about time. Took you long enough...
Old Dec 16, 2008 | 05:34 AM
tepid1's Avatar
Just send them back to Hasport. If you don't like them then you can always put the soft inserts back in. Hasport send you back the soft inserts when they mod them to the billet inserts.
Old Dec 16, 2008 | 06:42 AM
tony tone's Avatar
GDD Moderator
745whp = a given for solids.
Old Dec 16, 2008 | 10:06 AM
1slowcrx's Avatar
no one had a problem with the post mount ripping out of the block with solids or cracking?
Old Dec 16, 2008 | 10:43 AM
fasterthenU's Avatar
that is only on a block that has been in a car accident.
Old Dec 17, 2008 | 05:54 AM
hawkturbo's Avatar
pro an cons whit the Solid mount for DD use Help pls 450 hp in DB8 thas my gooal
Old Dec 17, 2008 | 06:31 AM
project dc2's Avatar
pros- no engine movement solid shifts , less axle breakage
cons- hard to deal with the vibrations for a daily, possible ripping out of chassis/ loosening /tightening bolts all the time. risk damaging block on a DD application
recommendation- some hard inserts such as 95A urethane innovative mounts or hasports 85A urethane
Old Dec 17, 2008 | 07:53 AM
AllMotorRandy's Avatar
you're too gangsta for all of us chad! did you have to get your teeth capped after driving? haha
Old Dec 17, 2008 | 11:22 AM
YZFR6's Avatar
I'd recommend solid mounts to any car making that much power. I refuse to send people anything other then solid mounts! Especially with that kind of power. Honestly... You'll have more of a solid driveline as well as no engine movement. With turbo set ups today on these crazy high HP cars. The last thing you need is something moving on you. If you already have the Hasport mounts I'd recommend sending them in ...
Old Dec 17, 2008 | 12:47 PM
1KWHP1G's Avatar
Cost me nothing to do this.I used scrap metal.
Old Dec 17, 2008 | 12:48 PM
1KWHP1G's Avatar
I left the rubber inset in the mount and just welded a metal plate on each side and welded the inside of the mount bracket for added strength.I also drilled a hole through the mount bracket,and inner mount seen in the pictures.I than put a Grade 8 bolt through it all so there is absolutely no movement at all.
Old Dec 17, 2008 | 12:58 PM
1KWHP1G's Avatar
Street cars don't need solid mounts.In most cases a fresh set of OEM mounts are all that is needed.Maybe front and rear poly inserts but a full set of solid mounts in a street car is not going to be fun to drive everyday nor is it really called for.
Old Dec 18, 2008 | 08:42 AM
zeekbuilt's Avatar
Banned
only costed you your time, and materials, and electricity, but well worth it
Old Dec 18, 2008 | 09:06 AM
YZFR6's Avatar
If you read his post, it's a race car... Look at his sig
But, thanks
Old Dec 18, 2008 | 09:11 AM
Boner_Ben's Avatar
But, thanks
This guy knows his mounts!
