solid motor mounts?
Old Feb 9, 2005 | 03:54 PM
paulzy's Avatar
Default solid motor mounts?
Well, my EF hatch is geting the heart put in for the first time in 1.5 years. If I were to make some solid motor mounts for my car, will the rear crossmember and engine be able to take the abuse from the mounts?
I ask because I have seen rear crossmembers crack in the older EF chassis due to too little flex in rear mount filler. I've also seen mounts rip right out of driver's side of the block before. I'm not sure if this was 100% due to the mountws, but I'm guessing the mounts make a difference as well
Are tubular rear crossmembers still legal in Hotrod?
Old Feb 9, 2005 | 04:16 PM
DaveF's Avatar
Default Re: solid motor mounts? (paul vang)
paul, i recomend building solid side mounts for the engine, that go to the frame rail. similar to that of the 92+ civic style mounts(jimfab lowers)
also it might be a good idea to do something similar to what tony did on the latest hotrod honda's that he's built(the tube that runs under the trans and connects the front and rear crossmember) it seems like it would act like an engine plate in a way.
i believe the tubular crossmembers are illegal ??? can anyone clarify?
Old Feb 9, 2005 | 04:19 PM
ninesecrx's Avatar
Default Re: solid motor mounts? (Dturbocivic)
Yeah, they are illegal.
Old Feb 9, 2005 | 09:23 PM
Modify's Avatar
Default Re: solid motor mounts? (ninesecrx)
since when rear tubular crossmember is legal ???
Old Feb 9, 2005 | 10:20 PM
paulzy's Avatar
Default Re: solid motor mounts? (Modify)
I thought they were ok'd a few years back when a couple guys started going tubular???
Old Feb 9, 2005 | 11:02 PM
JSpin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Modify &raquo;</TD></TR><TR><TD CLASS="quote">since when rear tubular crossmember is legal ???</TD></TR></TABLE>
i think that falls under the whole "back-half deal........i'd imagine that drops you into PRO.
correct me if i'm wrong please
teamrpm2
28
Nov 2, 2009 12:59 PM
EG6Boy702
33
Apr 27, 2009 03:55 PM
smokey.23
22
Mar 24, 2009 09:01 PM
HOUSTONb
Feb 4, 2009 08:03 AM
elmalouno
Oct 15, 2008 05:46 AM
