Solid front lower control arms
Old Jan 22, 2012 | 03:39 PM
  #26
.CUBISH.'s Avatar
Default Re: Solid front lower control arms
add me to the list
http://www.youtube.com/watch?v=F4902H0aGfg
Old Jan 22, 2012 | 03:52 PM
  #27
tepid1's Avatar
Originally Posted by daboogy
This design looks a lot better to me since its a continuous bar instead of being 2 pieces
Wat do u guys thinks about this design?
Who makes these?
Old Jan 22, 2012 | 04:14 PM
  #28
Divers's Avatar
That is the same design with gussets added. The problem I see is the front tube was drilled and a second tube was inserted perpendicular then welded. The front tube is too small for this type of joint. Drilling it removed almost all the tube and welding the inserted piece made the remaining material brittle. The insert should be a sleeved piece, not there at all, or at least a bigger front tube. Aftermarket LCA's would not be hard to make right. This is just a poor design; time for R2.
Old Jan 22, 2012 | 04:59 PM
  #29
EDLOVA23's Avatar
Both designs have gussets
The design looks pretty diff to me, the broken one looks like it was attached by being welded together with the rest of the arm
And this one is a complete tube goin across to the bearing
Old Jan 22, 2012 | 05:16 PM
  #30
Divers's Avatar
They both are one continuous tube. If yours breaks it will look just like the broken one. It will break where they welded the perpendicular insert to the front tube.
Old Jan 23, 2012 | 12:48 AM
  #31
Boosted_B_Series's Avatar
I have a few customers that just weld the front lca bushings up solid. They claim it solved their axle breakage issues.
Old Jan 23, 2012 | 01:11 AM
  #32
Zer0_SpeedWorks's Avatar
Why not use the oem arm then press sphearical bearings?
Old Jan 23, 2012 | 03:28 AM
  #33
wolve's Avatar
teflon instead of ES is a major upgrade already.
or else, why not run a ef/da style suspension and thus completely deleting the rear part of the flca?
Old Jan 23, 2012 | 08:39 AM
  #34
tepid1's Avatar
The rear part has a huge affect on the original arm. That's one of the keys to a good suspension setup in these cars.
Old Jan 23, 2012 | 09:45 AM
  #35
exgr's Avatar
Homosexual by choice
I like Chris @ KingPin Machine's work a LOT! I'll be using it for my ultimate road race/Time Attack del Sol rebuild...
Old Jan 23, 2012 | 12:49 PM
  #36
E Town DSM's Avatar
you can always keep it simple and use stock arms and be done with it. im sure theyll get you 90 percent of the way all the fancy stuff is for that extra 10 percent.
Old Jan 23, 2012 | 12:51 PM
  #37
dturbocivic's Avatar
agreed !!
Old Mar 8, 2012 | 06:33 AM
  #38
01DC4's Avatar
Anyone know what brand these are?
Old Mar 8, 2012 | 06:43 AM
  #39
EE2bitsk's Avatar
what's the weight difference?
if they've broke before, I don't know why anyone would opt for those over oem.
Old Mar 8, 2012 | 06:47 AM
  #40
90blackcrx's Avatar
Originally Posted by dturbocivic
this is off of Danny's FB page
Thats normal, I don't see any issues going on at all.
Old Mar 8, 2012 | 07:13 AM
  #41
YZFR6's Avatar
Agree'd! That aftermarket front lower control arm I've seen and heard to many horror stories. Even the cast ones that were available broke, just use the stock one and put Energy suspension bushings or whatever you feel will work for you. Keep it safe...
Old Mar 8, 2012 | 07:31 AM
  #42
Turboteg27's Avatar
Who make these arms?
Old Mar 8, 2012 | 07:39 AM
  #43
competition engineering makes them. they are garbage and will break. its just a matter of time.
Old Mar 10, 2012 | 11:03 AM
  #44
Patterson's Avatar
X2 I will also be running his product when mine goes back together for sure. Great guy and top notch product.
Old Mar 11, 2012 | 03:11 AM
  #45
zakura R's Avatar
Why no just run the stock one and call of the day !!
Old Mar 11, 2012 | 03:31 AM
  #46
SLIM NOTHING's Avatar
because people in this world are to stupid to reallize you dont need them.
I think its funny you see all these cars out there running 9's,8's,7's using stock lower control arms and you have people that buy junk like that and end up spending more money in the end when they break. just because it looks nice dosent mean its gonna work.
Its like this. you see the hottest chick in the world everything is perfect about her but she has aids. you say to yourself, but man she is hot id hit it, but still there is the aids situation. ahh who cares shes hot! then your burned.
Old Mar 11, 2012 | 04:42 AM
  #47
gogetta's Avatar
Lmfao!!
teamWARej1
14
Oct 21, 2012 07:10 PM
jruiz094
Suspension & Brakes
Oct 1, 2010 01:31 PM
offcamber
49
Apr 10, 2010 09:05 AM
PatrickGSR94
Suspension & Brakes
14
Dec 4, 2008 06:08 AM
underage
Mar 4, 2006 06:58 PM
