Solid front lower control arms
Old Jan 21, 2012 | 09:55 AM
EDLOVA23's Avatar
Default Solid front lower control arms
Im on the search for a set of complete solid front lower control arms, i know Competition engineering use to make them don't know if they still do anymore. Any other companies make them in chromoly?
Old Jan 21, 2012 | 10:04 AM
tepid1's Avatar
Default Re: Solid front lower control arms
What's wrong with OEM? There are companies that sell spherical bearings in replacement of the OEM rubber ones. It helps a lot.
http://kingpinmachine.com/ is a great company with quality Aurora bearings.
Old Jan 21, 2012 | 10:05 AM
cibao2ner's Avatar
check your pms...
Old Jan 21, 2012 | 12:53 PM
BIGTUNA's Avatar
http://www.specialprojectsms.com/per...hr-1-6248.html
I have dealt with this company a ton in the past I believe you can order just bushings if you want to use your old arms and press new ones in.
Zer0_SpeedWorks's Avatar
Pci also makes them.
Old Jan 21, 2012 | 01:27 PM
EDLOVA23's Avatar
oem ones are heavier...thanks for the link
thanks alot guys
Old Jan 21, 2012 | 01:33 PM
AROD's Avatar
thanks alot guys
Chris at kingping has made our CCC Racing "Drag" Version of the ones he has online for the road racing guys. It's a better bearing that has 9,000lb load bearing compared to the 3,000lb bearing he uses for the road racing guys. Its a little more than the prices he has online but you can get them thru us. Chris is a good guy to deal with!! full kit (UCA,LCA,Compliance bushings), all new parts.
Old Jan 21, 2012 | 02:58 PM
Divers's Avatar
PCI bronze bearing kit here. Great product and huge improvement over stock bushings.
http://passwordjdm.com/PCI-Bronze-Be...7529C1926.aspx
Old Jan 21, 2012 | 03:53 PM
BrowNKiD's Avatar
What about energy suspension bushing?
Old Jan 21, 2012 | 03:57 PM
dturbocivic's Avatar
anyone want to start a list on how many cars hit the wall with competition engineering lower control arms ?
Old Jan 21, 2012 | 04:06 PM
EDLOVA23's Avatar
Wats dat all about?
Old Jan 21, 2012 | 04:16 PM
this is the latest victim
http://www.youtube.com/watch?v=_eZxU...2&feature=plcp
Old Jan 21, 2012 | 04:21 PM
EDLOVA23's Avatar
Wat was actually the problem? Did the arm brake? was the nut for the lower ball Joint loose?
Old Jan 21, 2012 | 05:03 PM
1994turbocivic's Avatar
on youtube it says control arm broke
Old Jan 21, 2012 | 05:30 PM
this is off of Danny's FB page
Old Jan 21, 2012 | 05:49 PM
E Town DSM's Avatar
Saw a guy in Vegas a few years ago hit the wall and end up on the roof from same reason. The comp arms are not good stay away.
Old Jan 21, 2012 | 05:50 PM
EDLOVA23's Avatar
Wow Dats no good
Old Jan 21, 2012 | 06:00 PM
EDLOVA23's Avatar
Looks like the weld broke
Old Jan 21, 2012 | 06:24 PM
Joe Housley
Old Jan 21, 2012 | 06:28 PM
utahturbosohc's Avatar
Joe Housley
Always wondered how his car ended up wrong side up. I've seen pics, but never heard the story. That sucks.
Old Jan 21, 2012 | 06:29 PM
nonvtecallmotor's Avatar
These are what I use....
Old Jan 22, 2012 | 11:35 AM
redrum908's Avatar
thats some serious **** last thing you need going down the track is supension pieces breakin gon you ....
Old Jan 22, 2012 | 03:03 PM
Divers's Avatar
That's a poor design just looking at it. You can see that breaking a mile away.
Old Jan 22, 2012 | 03:32 PM
tony1's Avatar
The problem is for wheel clearance you can't do what's ideal. There HAS to be a bending moment from the shock fork out so it better be damn strong to live through the drive force.
Old Jan 22, 2012 | 03:35 PM
EDLOVA23's Avatar
This design looks a lot better to me since its a continuous bar instead of being 2 pieces
Wat do u guys thinks about this design?
