solid engine mounts
Old Sep 3, 2010 | 04:51 AM
  #26
Autoworks's Avatar
Default Re: solid engine mounts
Innovative Mounts
Old Sep 3, 2010 | 05:05 AM
  #27
YZFR6's Avatar
Originally Posted by zakura R
Hey guys me and my boy did urs own solid mount for my h2b evolution and my boy hasport mount
That's another way of doing it... Having the steel pin through the mount is very, very important. You don't want it to ovalize after a period of time. Not matter how solid the mount is, it still will transfer the torque somewhere. You also want to have the steel pin to be flush with the face of the solid mount, not pertruding it, the whole objective is to have the chassis bracket and/or bracket to sit flush with the face. You want as much material as possible to sit on the face of the mount. If it's just touching the steel insert, it'll flex and break your bracket(s) or ovalize the insert (steel or aluminum) it will happen. Hope that helps you
Old Sep 3, 2010 | 05:51 AM
  #28
TegraGSXR's Avatar
Not to tread jack, but at what time do you need to go to solid mounts. Im in the process of rebuilding my car and I need mounts. It will be about 50/50 street/drag. It will be around 500whp for the street and around 650 if I run race gas. I need mounts for it and not sure if I should run the 93 inserts or solid? Thanks for the input.
Old Sep 3, 2010 | 07:07 AM
  #29
YZFR6's Avatar
Honestly, 85-90A durometer inserts are useless... It yeilds a higher content of plastic, they still flex under load and I believe it was just a replacement at the time for not having a complete solid mount. If you're making that kind of power, I wouldn't worry about vibration. That's the number one problem, is that the general public want's to make crazy power and not sacriface comfort. I'm not sure if any of us can do that in these cars. The solid mounts would be the choice for performance benfits, to transfering power, no driveline movement and help a lot with wheel hop. I hope this helps you with your choice.
Old Sep 3, 2010 | 08:01 AM
  #30
sanman000719's Avatar
helps me decide thats for sure since driveline movement is what im having issues with
thanx to all for the replies
Old Sep 3, 2010 | 08:33 AM
  #31
cluelessmale's Avatar
you can just torch out the rubber of the mounts and weld in some metal
Old Sep 3, 2010 | 11:56 AM
  #32
I.C.C.'s Avatar
Thanks for the info tepid. I just emailed Hasport for more info on converting my current mounts, but I may still just sell them and get the Avids to avoid the hassle... It's nice to have the option though
Old Sep 3, 2010 | 12:46 PM
  #33
yeah i called them and yup 100 bux is it although they wanted to get me into a stiffer eurathane insert i just dont wanna hassle with it at all so solid it is for me
Old Sep 3, 2010 | 01:35 PM
  #34
TegraGSXR's Avatar
Originally Posted by YZFR6AVID
Honestly, 85-90A durometer inserts are useless... It yields a higher content of plastic, they still flex under load and I believe it was just a replacement at the time for not having a complete solid mount. If you're making that kind of power, I wouldn't worry about vibration. That's the number one problem, is that the general public want's to make crazy power and not sacrifice comfort. I'm not sure if any of us can do that in these cars. The solid mounts would be the choice for performance benefits, to transferring power, no drive line movement and help a lot with wheel hop. I hope this helps you with your choice.
Thank you for the reply. I was leaning towards the solids. I have Kirkey Pro Drag seats and a ten point cage going in, so I'm not to worried about that much "comfort". Ill definitely be getting the solids. Thanks
Old Sep 3, 2010 | 02:36 PM
  #35
FarmYard's Avatar
cut a hole in some flat bar and weld it to the mount.cheep and easy.
Old Sep 3, 2010 | 03:11 PM
  #36
Hasport's Avatar
Originally Posted by sanman000719
so hasport makes solid mounts???????????
we make solid inserts for our mounts
Originally Posted by tepid1
They sure do. Call them up and talk to Brian. He's the man over there....
or you can talk to me
Originally Posted by sheepey
Nice product..hows the wait? couple days or months?
takes a day or 2 to machine the mounts out to accept the solid inserts
Originally Posted by h2.4
I think thats what he is saying, you can order the aluminum solid inserts for your mounts that have urethane in them previously. that way you don't have to buy new mounts to get solid mounts.
that is correct
Originally Posted by OMG B16
They do make the anodized black inserts, when when they are in front of you you cant tell they are solid untill you touch them.
the inserts are anodized black
i remember talking to you
Old Sep 3, 2010 | 06:28 PM
  #37
yup man im going to have this done for sure im currently in transition from kansas to ky though lol so it might take a second
Old Sep 3, 2010 | 06:36 PM
  #38
crxmansir's Avatar
Do you locktite everything? But it will bark 4th real nice.
GoLowDrew
Jun 25, 2013 08:34 AM
Scracho
Nov 18, 2005 03:51 PM
CW_97_ITR
Aug 18, 2003 07:00 AM
LbcJiGGa
Feb 24, 2003 07:17 PM
sCeRaXn
29
Oct 18, 2002 09:19 AM
