solid engine mounts
Old Aug 1, 2007 | 01:41 PM
94turboeg's Avatar
Default solid engine mounts
How sells or makes solid engine mounts?
Old Aug 1, 2007 | 05:51 PM
1992Si's Avatar
We had ours made by a buddy who is a fabricator. He does a lot of work for our car.
Is this what your looking for?
Modified by 1992Si at 8:26 PM 8/2/2007
Modified by 1992Si at 8:35 PM 8/2/2007
Old Aug 1, 2007 | 06:13 PM
MrParks's Avatar
Default Re: solid engine mounts (94turboeg)
pm me j, i got some good news
Old Aug 2, 2007 | 01:59 PM
94turboeg's Avatar
Default Re: solid engine mounts (MrParks)
anyone ?
Old Aug 2, 2007 | 02:15 PM
Kyle R's Avatar
Also interested to know this...
Old Aug 2, 2007 | 02:19 PM
MrParks's Avatar
Default Re: solid engine mounts (herecomesboost)
innovative mounts has a billet 85a insert which i have no movement what so ever.
you can also request a billet insert from them as well.
http://www.innovativemounts.com or contact http://www.camp1320.com for instock 85a's
Old Aug 2, 2007 | 02:47 PM
bazda's Avatar
Why dont you just get your standard ones filled with Urethane. It will make them solid and its cheap to get done as well.
Old Aug 2, 2007 | 03:04 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: solid engine mounts (bazda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bazda &raquo;</TD></TR><TR><TD CLASS="quote">Why dont you just get your standard ones filled with Urethane. It will make them solid and its cheap to get done as well.</TD></TR></TABLE>
honestly, urethane is not solid.
i am actually looking into them now.
Old Aug 2, 2007 | 03:12 PM
Turbo-charged's Avatar
Default Re: solid engine mounts (boostedcivicsir)
i just made some 100% solid metal mounts. it was a pain in the *** but something i have been trying to find the time to do for the last 2 years. i think i took some pictures.
Old Aug 2, 2007 | 04:04 PM
G2K's Avatar
G2K
Default Re: solid engine mounts (Turbo-charged)
I have the innovative mounts for my K with the 85a, I haven't tested them yet, but just removing the inserts to powdercoat the mounts, I have to say its some pretty hard stuff.
Old Aug 3, 2007 | 01:21 AM
94turboeg's Avatar
Default Re: solid engine mounts (G2K)
solid billet anyone made these?
Old Aug 3, 2007 | 04:12 AM
Turbocivic94's Avatar
85a mounts from innovtive is some good ****. no movement
Old Aug 3, 2007 | 05:10 AM
1992Si's Avatar
I think we paid $100 to have the solid ones made that I posted above.
Is this a full race car ?
Old Aug 3, 2007 | 05:50 AM
underpressure02's Avatar
I made my own about 3 years ago after seeing dturbocivics. I also run solid mounts on the daily driver.
Old Aug 3, 2007 | 08:00 AM
1992Si's Avatar
Solid mounts + Daily Driver = Animal
Yea it seems real easy to make your own if you have a welder.
Our's bolt to the 3 bolts that hold the traction bar on the chassie.
Old Aug 3, 2007 | 10:05 AM
jeffsciv23's Avatar
i filled my last mounts with 94a poly from Grainger, worked great and was stiff as hell. only costed $30
Old Aug 3, 2007 | 03:44 PM
93LSivic's Avatar
Default Re: (jeffsciv23)
I have had some billet inserts made for my hasports. Still uses the metal tube the bolt passes through, without it (if they were all aluminum) they would start to gall and eventually cause damage to the chassis. Dont have any pics, but could probably get some if you'd like to check them out
Fabworx
Sep 4, 2010 04:01 AM
vtechboyz
Dec 17, 2008 07:13 PM
sixtodc2
Jul 13, 2007 12:43 PM
01gizzer
May 30, 2002 11:56 PM
