Smallest open trailer?
Old Dec 9, 2006 | 10:44 PM
turtle-eg's Avatar
Default Smallest open trailer?
Does anyone know what's the smallest (length and width) open trailer I can get to tow my '95 hatch? I'm currently towing with a dolly but hate the fact that I can't back up with it. Should I go with a dual axle or single axle?
I don't have much room for parking, so I would have to get the smallest possible.
Thanks in advance.
Old Dec 10, 2006 | 05:14 AM
Slow00si's Avatar
Default Re: Smallest open trailer? (turtle-eg)
get a dual axle a full weight car on a single axle tows terrible, and get a 18ft a smaller one will work but you have no room to hook tie down straps plus if you ever need to tow anything bigger you cant
Old Dec 10, 2006 | 06:23 AM
fmfkid250's Avatar
I towed both, what are you towing with?
i had my hatch on a small utility trailer, drove 250miles no nopi ny and 300 miles to mir, single axle, i never got to measure it so i am not totally sure what size it was,
it dident pull bad if i would get up past 75mph it wouldl feel like ****, i also was towing it with my 97jeep little cherokee
Old Dec 10, 2006 | 07:41 AM
smokey2.0's Avatar
i would tell you to suck it up, and stick with the dolly! a 18' trailer will need about 22' of linera space, for you to be able to park it at your house. you could buy a single axle(14' i'm not really sure on the lenght, aluminum trailer(light, and expensive). my friend had one, that he used to pull with his crv. he towed a civic hatch(eg), completely stripped maybe 1800lbs!
Old Dec 10, 2006 | 09:13 AM
boostedcivicsir's Avatar
Mr. Badwrench
i have a 16" open deck, my civic has about 1" of side between the front tires with the slicks on it, and fits just fine in the middle. my friend also fit his 68 Cutlass on it as it was his before i bought it fro him.
Old Dec 10, 2006 | 11:49 AM
bracket 4 life's Avatar
Default Re: Smallest open trailer? (boostedcivicsir)
i also have a 16ft and like it for towing my civic and integra.
Old Dec 10, 2006 | 12:12 PM
Garage 808 Hatch's Avatar
http://www.hondamarketplace.co...48067
here's mine, works awesome
^^^^^^^^ for sale
Modified by Garage 808 Hatch at 3:02 PM 12/10/2006
Old Dec 10, 2006 | 12:42 PM
Newt Dog's Avatar
Default Re: Smallest open trailer? (bracket 4 life)
I have a 16ft diamond plate solid floor trailer. It measures 20ft from tounge to rear. I park it in my garage with my crx on it. Garage is 24x24. . Tow vehicle is a 1990 power ram 3/4 ton.
Old Dec 10, 2006 | 02:16 PM
smokey2.0's Avatar
Default Re: Smallest open trailer? (Newt Dog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newt Dog &raquo;</TD></TR><TR><TD CLASS="quote">I have a 16ft diamond plate solid floor trailer. It measures 20ft from tounge to rear. I park it in my garage with my crx on it. Garage is 24x24. . Tow vehicle is a 1990 power ram 3/4 ton. </TD></TR></TABLE>how many axles? got some pictures?
Old Dec 10, 2006 | 05:34 PM
josh green's Avatar
I would get a tandem axle trailer just for the stability. Its pretty unstable to tow with a single axle at hwy speeds. You can get a nice 16-18' for a little over $1000.
Old Dec 10, 2006 | 05:42 PM
Default Re: (josh green)
yes, its really that low
Old Dec 10, 2006 | 05:45 PM
jamheg1101's Avatar
It will fit on a 7.5 by 14ft trailer. I have that size but an enclosed trailer and my s2000, crx, and hb all have fit in there one at a time. It is very tight but totally doable.
Old Dec 10, 2006 | 08:54 PM
Pro-Am 1934's Avatar
Default Re: (jamheg1101)
Just remember to at least get a tandem axle trailer. Don't spend the money on a small single axle. They will pitch while reversing just the same as a dolly. I would go with the Big Tex 60CH. It is their cheapest open trailer with a wood floor. It will cost you about $20 a D ring to get installed. You can get them in a 7' x 16'. They are light enough to be towed by a Tacoma.
Jason
Old Dec 10, 2006 | 09:01 PM
1 2 NV's Avatar
i also have a 16' open bed trailer. i wouldnt go any shorter. the length of a hatch is roughly 12'. i can still fit my cooler in front of the car.
Old Dec 11, 2006 | 04:05 AM
1992Si's Avatar
rota92 and I bought a Bre-Mar 18ft full deck with drop rear and a 4500lbs SuperWrench for under $3500.00. Tandem axle, tow it with a 97 Suburban.
Don't cheap out if you plan to tow a lot and have lots of money invested in your set up.
Welcome to the big time...
Old Dec 11, 2006 | 05:14 AM
smokey2.0's Avatar
Default Re: (Pro-Am 1934)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pro-Am 1934 &raquo;</TD></TR><TR><TD CLASS="quote"> I would go with the Big Tex 60CH. It is their cheapest open trailer with a wood floor. Jason</TD></TR></TABLE>jason what's the price on this trailer? the total lenght for these trailers are 14 footer is 17.29 feet, and for the 16 footer is 18.45 feet. good sizes, if youi have a garage that's only 20'x20'!
Old Dec 11, 2006 | 05:38 AM
nasteboyii's Avatar
Default Re: (1992Si)
I AGREE w/1992si
i have a 18 bri-mar closed deck diamond plate, hidden ramps, dual axle w/brakes
i tow like a mad man w/my f250 gas, no problems no worries, its heavy but worth it, the heavier the more stable, slowing down is alittle different story
Long story short, the better the trailer the less to worry about, trailer brakes are a must in my opinion, panic stops are not panics when u have trailer brakes
if u have alot of money in your car, can u afford get get a cheap trailer and possible have a accident/incodent and loose alot more then the few extra bucks in the trailer
Good luck
dan
Old Dec 11, 2006 | 07:08 AM
B18c1turboedEK's Avatar
Default Re: (nasteboyii)
Heres mine it belive its 14 foot long. Its not very wide,i cant get the car on there with slicks,thats sucks but i got it too cheap too pass it up
Old Dec 11, 2006 | 08:32 AM
eh, i guess its a matter of opinion, mine has no brakes, but with a crew cab long bed in front of it, doesnt really need em. i've used mine to tow from nor cal to central Oregon, no problems. how high are the decks on those trailers?
Old Dec 11, 2006 | 08:33 AM
Newt Dog's Avatar
Default Re: Smallest open trailer? (smokey2.0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokey2.0 &raquo;</TD></TR><TR><TD CLASS="quote">how many axles? got some pictures? </TD></TR></TABLE>
Tandum axles. It's an anderson, 2 year's old with less than 800 miles on it. I stole it for $2500.
Tandum is the way to go. Stable as ****. With my dodge I cant even tell it's behind me!
Old Dec 11, 2006 | 09:02 AM
JSpin's Avatar
i have a 16' dual axle and it works just fine for me, no complaints other than it's not enclosed, haha.
something to really keep in mind when trailer shopping is height of the trailer and length of the ramps. loading low cars onto a high trailer with short ramps is NOT FUN. if you've gotta pay a couple hundred bucks more to get longer ramps with a dove-tail, go for it.
Old Dec 11, 2006 | 04:50 PM
1 2 NV's Avatar
Default Re: Smallest open trailer? (JSpin)
i paid right around 2k for my trailer brand new, heavy duty, with dove tail 16' which i said in an earlier post.
Old Dec 11, 2006 | 05:13 PM
smokey2.0's Avatar
Default Re: Smallest open trailer? (1 2 NV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 2 NV &raquo;</TD></TR><TR><TD CLASS="quote">i paid right around 2k for my trailer brand new, heavy duty, with dove tail 16' which i said in an earlier post.</TD></TR></TABLE>post some pictures!
Old Dec 11, 2006 | 06:09 PM
turtle-eg's Avatar
Price isn't really an issue for me... it's just finding parking for it. I don't mind spending 2-3k for a trailer, but I don't want to pay 200 a month to store it.
As for sticking with my dolly, I hate it because 1. I can't backup with it and 2. I smacked the side of my car twice already while making a really tight turn into a driveway.
Old Dec 11, 2006 | 07:48 PM
1 2 NV's Avatar
you know i dont think i have any pics of the trailer. plus its at my buddies house so i cant take any unless i go over there.
