slow EVO
Old May 24, 2004 | 07:13 PM
Boltz's Avatar
Default slow EVO
Something is not right here. The car belongs to my brother and I've tried searching for some answers at EvolutionM.net, but found nothing out other than most members there are retarded. Id like to do a compression/leakdown test, and Dyno it with a wideband reading but its not my car.
Evolution8-
K&N Intake
Greddy ProfecB @ quick spike to 22 then levels to just around 21
Re-flashed ECU
TurboXS 3" cat-back
Forge BOV
R/T - .344
60' - 1.837
330' - 5.579
1/8 - 8.680
1/8mph - 80.33
1000' - 11.362
1/4 - 13.602
1/4mph - 100.56
TIA
Old May 24, 2004 | 07:16 PM
Suprdave's Avatar
Default Re: slow EVO (Boltz)
Shifting Slow?
Only thing I can think of from that slip...his launch was great.
Old May 24, 2004 | 07:24 PM
Boltz's Avatar
Default Re: slow EVO (Suprdave)
sounded and looked pretty good, but crazy considering motor trend pulled 105mph
Old May 24, 2004 | 07:41 PM
ModenaTwinTurbo's Avatar
who did the reflash and was it one of those mail in reflashes?? probably hurt the motor... or a boost leak... check the clamps if they are all still stok i believe one that is near the blow off valve always needs to be checked they become loose easily or something like that... and yeahh check the compression..
Ed-
Old May 24, 2004 | 07:46 PM
Boltz's Avatar
Default Re: slow EVO (ModenaTwinTurbo)
the dyno is done by a guy named al on evolutionm.net
ive read nothing but good things about it, and I believe his evo runs 11.4
Old May 24, 2004 | 07:54 PM
yepp he does a good job. and he run's 11.2's.. well if he's not shifting slow i'd say that he's got a hurt motor... considering that the car was probably dynoed at a number close to 300 if not over. so do the compresion test. and check for boost leaks.
Ed-
Old May 24, 2004 | 08:03 PM
MyCarGoesVroom's Avatar
I believe the Evos are tuned to have a recirculating BOV and they lose power if you have a BOV that vent into the atmosphere rather than recirculate. That might be a problem, unless the ECU reflash fixes this issue.
Old May 24, 2004 | 08:04 PM
Boltz's Avatar
Default Re: (MyCarGoesVroom)
the bov is recirculated
Old May 25, 2004 | 09:20 AM
Boltz's Avatar
Default Re: (Boltz)
TTT
Old May 25, 2004 | 09:23 AM
Jokerluv's Avatar
not to sure on this
Old May 25, 2004 | 10:20 AM
Boltz's Avatar
Default Re: (Jokerluv)
Old May 25, 2004 | 11:26 AM
ATS*Mark's Avatar
OG triple OG
Default Re: (Boltz)
get it on the dyno and see.
ImPuLsIvE
May 15, 2008 08:13 AM
Luserkid
20
Jun 4, 2004 07:50 AM
95turbohatch
Mar 7, 2004 09:59 AM
crx1856
Oct 25, 2003 04:34 PM
BoostedGSRBubble
May 21, 2003 07:48 PM
