Slow car question
Old Oct 12, 2009 | 01:57 PM
Mike Hawke's Avatar
Default Slow car question
What kind of all motor set-up would I need to run consistant low 14s @ around 100mph in a EG or EK coupe? My heavy *** integra gsr runs 14.7 with just intake, used POS dc header and catback.
I was thinking maybe a JDM gsr with full bolt ons and tune? Or maybe b20vtec?
Old Oct 12, 2009 | 03:15 PM
SonicRacing1's Avatar
Default Re: Slow car question
we need a little more INFO if you expect sumone to come up with a good answer
Old Oct 12, 2009 | 03:24 PM
Puma909's Avatar
Sonic that makes two of us that are Bisimoto tuned. Bisi knows his stuff.
Old Oct 12, 2009 | 04:04 PM
Mike Hawke's Avatar
I just want something all motor in a coupe ( They are roughly 2300 - 2500 lbs ) that will trap at least 100mph. What motor set up or power do you think I will need?
Old Oct 12, 2009 | 04:07 PM
base-op.1320's Avatar
Just do cams a tune and a better header and you might be able to get your low 14's you want.
Old Oct 12, 2009 | 04:10 PM
MR.POWERSHIFT's Avatar
Throw that motor in the hatch and call it a day
Old Oct 12, 2009 | 04:50 PM
Mike Hawke's Avatar
I don't want a hatch and I really don't want the teg anymore. I want to piece together a eg or ek coupe.
Old Oct 12, 2009 | 05:18 PM
mar778c's Avatar
Community Builder
Community Influencer
This guy put together a simple motor that makes decent power.
https://honda-tech.com/forums/showth...2645256&page=2
fun reading
Old Oct 12, 2009 | 05:27 PM
okay let me ask you are you planning on using the SOHC or swapping for DOHC
Old Oct 12, 2009 | 06:05 PM
Mike Hawke's Avatar
a dohc of course, like a full bolt on jdm GSR engine or b20vtec set up.
Old Oct 12, 2009 | 07:17 PM
an you only wanna go mid or low 14's!! a GSR with bolt ons in a EG or EK coupe will do that with no problem header,ctr cams,any aftermarket intake manifold on a s100 ecu
on a set of 22"slicks an you should run low 14's high 13's
Old Oct 12, 2009 | 07:28 PM
KATAPLT's Avatar
If you drop in a gsr + weapon r secret weapon intake, a good header, tuned exaust, skunk 2 intake manifold,unorthodox pulley set, nology hotwires, & an external coil, & a reflash, you can hit low 14's In a 2800lb FF or better guarenteed!
jdmh22eg2
Engine Management and Tuning
Jun 12, 2013 02:15 PM
ShiftRed
11
Oct 21, 2008 02:24 PM
1.8u
Feb 17, 2005 06:35 AM
