which slicks to use??
Old Aug 26, 2002 | 02:14 PM
tygsr's Avatar
Default which slicks to use??
K I did a search and found some answers but not exactly what I was looking for. Want to run slicks on my stock gsr rims..I will be pushing around 350-400 hp to the wheels...will a 24x8.5x15 be best or something different..new to the whole slick idea, I want to get traction for once....
Old Aug 26, 2002 | 03:39 PM
martini's Avatar
Default Re: which slicks to use?? (tygsr)
350-400hp and you don't have the money to buy a proper set of drag rims?
Old Aug 26, 2002 | 03:42 PM
Incognito's Avatar
Default Re: which slicks to use?? (martini)
Hahahahahaha
On a more serious note, 400hp and slicks on stock GSR wheels aren't really gonna work too well. Invest in some 13" drag wheels, like Lensos. They're somewhat inexpesive. 24.5x8x13" seems right.
tygsr's Avatar
ya that hp made me broke...
Old Aug 26, 2002 | 03:57 PM
tygsr's Avatar
will lenso wheels handle that much hp? and I know slicks will be better, but what are your 1/4 time gains with slicks over a bfgoodrich drag radial??
Old Aug 26, 2002 | 05:05 PM
rotten's Avatar
Dude... get real drag tires.
I am amazed sometimes when people spend all the money on the motor and ignore the most important part of the car--tires/wheels and suspension--which are also usually the cheapest to upgrade.
Get some M/T's and some Bogarts or Lensos or something... it will be worth the investment, even if you have to sell some of the go-fast or look-good parts of your ride.
Old Aug 26, 2002 | 05:25 PM
tygsr's Avatar
Default Re: which slicks to use?? (rotten)
I am trying to sell my body kit for that very reason...no buyers yet..
Old Aug 26, 2002 | 07:22 PM
EVOCELICA's Avatar
New User
I run a set of lenso toms and I have them wrapped with M/T 24.5x8x13 and they grab real good, Nothing like a good wrinkle wall to get the power to the ground
Old Aug 26, 2002 | 09:07 PM
ExospeedAMcrx's Avatar
Default Re: which slicks to use?? (EVOCELICA)
the GSR wheels are only a 6 inch wide i believe. you need at least a 7.5 inch wide rim to put most of the slicks on. and the GSR rims are pretty heavy.
You'll be able to push some 22x9x13, 24x8.5x13 on lensos or some Bogarts.
With your HP, you'll overpower the street radials easily.
Wil
Old Aug 26, 2002 | 10:49 PM
Incognito's Avatar
Default Re: which slicks to use?? (exospeedAMcrx)
If you're stuck on using stock rims, you can run the 22x8x15" slicks. They fit, and don't buldge out the sides too much. If you run Mickeys, I think they have a 23.5x8x15" that also fits.
Old Sep 2, 2002 | 09:02 PM
TREVER's Avatar
Default Re: which slicks to use?? (Incognito)
24.5-8-13
bogart or lenso
Old Sep 4, 2002 | 07:10 AM
oc_civic's Avatar
ok help me out here i don't know anthing about slicks... how do these roll size wise.. i mean my car sits pretty low... if i have 15in rotas all teh way around, with kumho 205's and get 2 more slips with these slicks, that you are describing.. will teh car sit right? will i have rubbing issues if i don't normaly?
thanks for the help..
Old Sep 4, 2002 | 07:48 AM
autoEXturbo's Avatar
i'm in the same boat as you man, i spent all my money on the damn motor and didn't think to much about getting all that power to the ground. Well i did, but a little to late. No i'm not talking about my current setup. Now i have to invest in an 8point roll cage, helmet, a better suspension, and slicks and skinnies. Oh well more ramon noodles. Good luck with your decision.
Old Sep 4, 2002 | 01:16 PM
flip1199's Avatar
Default Re: which slicks to use?? (autoEXturbo)
What size slicks will fit some 15in rota slipstreams???
Old Sep 4, 2002 | 01:36 PM
oc_civic's Avatar
Default Re: which slicks to use?? (flip1199)
when you find out let me know...
kevin7200
Apr 21, 2015 08:34 PM
lsvtec86
Apr 13, 2014 02:33 PM
93H22ACX
Jul 14, 2004 02:38 AM
TOFU.man
May 27, 2004 01:35 PM
