slicks question
Old Apr 14, 2009 | 01:37 PM
H2BSTUPID's Avatar
Default slicks question
hi my buddy gave me some slicks (free) lol
they are 8/22/13
will this be ok with a h2b swap using a b16 tranny? or do you think it they are too small and i should run a bigger size???
Thanks
Old Apr 14, 2009 | 02:05 PM
JayWest's Avatar
Default Re: slicks question
stock motor? how much power are you making?
Old Apr 14, 2009 | 02:23 PM
Ls_dx's Avatar
What kind of shape are they in? Since they are free, and if they are in good shape.. Id rock them til you can afford to throw money at some Sticky mickey 24.5's
Old Apr 14, 2009 | 03:14 PM
H2BSTUPID's Avatar
yes the engine is pretty much stock with the usual bolt on's
70mm tb, 3 inch intake, kidd drag header and my 3 inch exhaust.
i know i'll move up in sizes when my head is finished being built!
as for the slicks they have lots of life left! i'll try them out and if they are not too small i'll keep them for now!! lol they are free!!
Old Apr 14, 2009 | 06:08 PM
boostinsidewayz's Avatar
def get some 23x8s when you are done with these
Old Apr 15, 2009 | 06:31 AM
H2BSTUPID's Avatar
thats the plan!!
but do you think i will run out of gear in 4th down the track?
Old Apr 15, 2009 | 10:31 AM
Dark_Teg's Avatar
Originally Posted by H2BSTUPID
thats the plan!!
I got my car well over 100mph in 4th gear the other day with more left and got the same tranny as you and 22 inch tires.
**I was on a deserted road with no cross streets and was checking air to fuel ration with my wideband and as I suspected the motor was running too lean at the top of 4th.**
Old Apr 15, 2009 | 02:10 PM
lunatics209's Avatar
thats the plan!!
maybe you will run out of gear. i have a gsr tranny and i almost ran out of gear. redline set at 8300 and finished at about 7800 in fourth. my friends redline was a bit lower and he was running b16 tranny trapped 101-102 and he had to go into fifth. both of us were running 22's.
Old Apr 15, 2009 | 05:16 PM
NAH2B's Avatar
thats the plan!!
i had to rev each gear to over 8500 rpm to cross the traps at 8500 rpm in 4th w/ 23" slicks b16 trans
you wont be happy w/ the 22's they are too small and they wont hook
also slicks should be thrown away after each season no matter how much life is left on them.
Old Apr 15, 2009 | 05:21 PM
jdmteg11sec's Avatar
hey lunatic what mods do u have on your stock h22 to be getting those number, like what ecu chipped ,tune, map, vtec kick in, redline, are you using 2 step, just looking for some specs to use for my h2b steup...
Old Apr 15, 2009 | 05:22 PM
damndude_92's Avatar
New User
i had 20x8 w my b16 and i still had some gear left all you can do is try them out and see how they perform diffirent drivers and diffirent cars do difirent things
Old Apr 16, 2009 | 03:26 AM
H2BSTUPID's Avatar
hmmmm, well my rev limiter is set to 8500 rpms!! so worst comes to worst i get it up there!! lol i will try it out!
Old Apr 16, 2009 | 11:31 AM
if its at 8500 you might be fine. that is pretty high for an h series though. considering stock is like 7700? i took mines to 8000 rpms nothing more though.
Old Apr 16, 2009 | 11:40 AM
it comes down to how much power you made. what was your redline. how fast you trapped. was it on an h2b setup too?
egjdmcivichatch
Aug 12, 2011 11:18 PM
Hondaruss
Nov 8, 2007 02:55 PM
turbodsmpower
May 29, 2003 10:35 AM
98civicEX
Apr 27, 2002 12:13 PM
HX_Guy
Jul 14, 2001 10:37 PM
