slicks
Old Jul 21, 2004 | 07:47 PM
CNSK's Avatar
Default slicks
Ive searched but not exactly sure what to run. I have a 00 civic hatch with jdm b18c type R. Pretty much stock with basic bolt ons...should i run 22x8x14s on my car or run drag radials? or leave it stock tires? any size recommendations? should i start out with 10 psi (tire pressure) and drop it down? Never ran slicks before so kinda need to know what to expect and if so is it necessary to heat it up?
Can I also run this tire size on my 95 teg gsr? basic bolt ons....
thanks
Old Jul 22, 2004 | 07:33 AM
93H22ACX's Avatar
Default Re: slicks (Moua)
best all motor size is 22x7.5x13 or 22x8x13
Old Jul 22, 2004 | 10:21 AM
CNSK's Avatar
Default Re: slicks (93H22ACX)
these can be mounted on stock donuts correct?
Old Jul 22, 2004 | 10:22 AM
93H22ACX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Moua &raquo;</TD></TR><TR><TD CLASS="quote">these can be mounted on stock donuts correct?</TD></TR></TABLE>
i asked the same thing in one of my posts. people say it can be done but its not safe since the CX steelies are like 13x5
i know that 9's can fit on 7.5's but i think 8's on 5 i too big
Old Jul 22, 2004 | 08:51 PM
2xtrme's Avatar
I have the same motor as you in my Civic coupe, except with a Toda valve train, and I can hook up all right with 205/50/14 drag radials. I'm still losing traction, but am getting 60ft's in the 1.9's. I'm looking for a slick now to try and break into the 12's, but unfortunately they do not make a 22x8x14, so I'll have to swith to a 15" rim.
Old Jul 22, 2004 | 09:47 PM
marieT1GRL's Avatar
try the 13x22'sx8
Old Jul 23, 2004 | 02:49 AM
93H22ACX's Avatar
Default Re: slicks (ThatOneGirl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThatOneGirl &raquo;</TD></TR><TR><TD CLASS="quote">try the 13x22'sx8 </TD></TR></TABLE>
my thought exactly...22x8x13 on 13" lenso's
Old Jul 23, 2004 | 06:54 AM
2xtrme's Avatar
Is there really that much difference in traction between a 13" and 15" slick?
Old Jul 23, 2004 | 07:45 AM
SlicksMH's Avatar
Default Re: slicks (2xtrme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2xtrme &raquo;</TD></TR><TR><TD CLASS="quote">Is there really that much difference in traction between a 13" and 15" slick?</TD></TR></TABLE>
Hi 2xtrme; The sidewall on the 13" will have more bite on the track then a 15" and you have more sizes to choose from when it's time step up.
John@M&H-Hashims
Old Jul 24, 2004 | 01:30 PM
CNSK's Avatar
Default Re: slicks (SlicksMH)
any cheap places to buy lensos? or other small and cheap 13's?
Old Jul 24, 2004 | 01:41 PM
DEVIOUS_EG*'s Avatar
contact Will at exospeed
Old Jul 25, 2004 | 08:18 AM
CNSK's Avatar
Default Re: slicks (DEVIOUS_EF*)
what psi do you guys put into? is it always neccessary to heat up the tires before going to the line?
Old Aug 4, 2004 | 07:00 AM
Charlie Moua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Moua &raquo;</TD></TR><TR><TD CLASS="quote">what psi do you guys put into? is it always neccessary to heat up the tires before going to the line?</TD></TR></TABLE>
psi... try something like 28-32psi.
not needed but works well and you'll get slightly better hookup out the hole.
NA making less than 200whp I'd get 22 x 7.5 x 13 lenso vdp!
Old Aug 4, 2004 | 07:04 AM
93H22ACX's Avatar
Default Re: slicks (Charlie Moua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua &raquo;</TD></TR><TR><TD CLASS="quote">
NA making less than 200whp I'd get 22 x 7.5 x 13 lenso vdp!</TD></TR></TABLE>
that high of psi with ET drag slicks??? i set my slicks to 10psi before the burn out and my buddy with his turbo application sets his to 6psi before the burn out too...
60' are high 1.7 to low 1.8's
Old Aug 4, 2004 | 07:42 AM
damn... 10psi.. that a hell of a wrinkle wall... hehe
the lowest i run on my 22/13's are 22psi... but still not that much difference in traction as 26psi
ms1motorsports's Avatar
28-30 PSI is way too much for a slick. I run 6PSI before the burnout on a turbo CRX and after the burnout PSI raises about 1-2 PSI depending on how long I heat the tires for. Start out with 10PSI and work your way down from there.
Old Aug 4, 2004 | 07:44 AM
93H22ACX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua &raquo;</TD></TR><TR><TD CLASS="quote">damn... 10psi.. that a hell of a wrinkle wall... hehe
the lowest i run on my 22/13's are 22psi... but still not that much difference in traction as 26psi</TD></TR></TABLE>
try 10psi...your 60' should be better
Old Aug 4, 2004 | 07:49 AM
SadisticRacing's Avatar
I use the M&H 22x8x13's and John from M&H was at my last race and we started at 12psi and went all the way down to 9psi. 60fts went from high 1.8's to high 1.7's. I run 22psi on my street tires and ran 14psi on Drag radials.
Old Aug 4, 2004 | 07:52 AM
93H22ACX's Avatar
Default Re: slicks (SadisticRacing)
sounds right to me!
Old Aug 4, 2004 | 07:58 AM
Griffin@Camtech's Avatar
start at 10 and go down from there
Old Aug 4, 2004 | 02:43 PM
crazyimport's Avatar
Default Re: slicks (Stickdeath)
20-30 psi.. WOW u guys are on crack lol
i was runnin 15psi on my mickeys and i got a few 1.6 60' foots last year
B18C5_VTEC
Jul 6, 2007 08:27 AM
Turbo O
Oct 16, 2006 08:38 PM
RedEj8
Oct 5, 2005 08:54 PM
MUGEN_B16CIVIC
Feb 4, 2004 09:52 AM
slowassgsxr750
Mar 11, 2003 11:57 PM
