slick size
Old Jan 10, 2007 | 08:15 PM
TurboSohc3369's Avatar
Default slick size question
I currently am running a sohc vtec with 348hp and 318tq at 24.6 psi. I got a set of m/t 24.5x7x13 mounted on 13" steelies. how do you folks think the slicks would be on some bogart 13x9? thanks for the imput.
Modified by TurboSohc3369 at 9:42 PM 1/10/2007
Old Jan 10, 2007 | 09:11 PM
ExospeedAMcrx's Avatar
Default Re: slick size question (TurboSohc3369)
you shouldnt mount a 7" wide slick on a 9" wide rim. Slicks have a specified range of rim widths that they can be mounted on. They usually are within 1-1.5" smaller than the rim width.
If you have an 8.5" slick, it usually requires something a 7.5-8" wide rim to fit the best so you will have the best contact patch on the tire.
Old Jan 10, 2007 | 09:24 PM
Default Re: slick size question (exospeedAMcrx)
how about a set of lenso 13x7.5?
Old Jan 10, 2007 | 09:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboSohc3369 &raquo;</TD></TR><TR><TD CLASS="quote">how about a set of lenso 13x7.5?</TD></TR></TABLE>
the 7.5" is closer to the slick width, its better than the 9" of course. are you set in using that particular slick size? you might get better traction with a wider slick.
23x8x13 or even a 24.5x8.5x13
Lenasec12
Sep 18, 2017 05:08 PM
saleensolution
May 21, 2006 12:20 AM
MassCivicMan987
Apr 14, 2006 08:00 PM
beedoublejay
Jul 21, 2003 10:26 PM
J2turbo21
Apr 16, 2003 01:31 AM
