Skunk 2 Pro1 Problem
Old Jul 10, 2013 | 12:55 PM
kissifur's Avatar
Default Skunk 2 Pro1 Problem
Hello every one, i have 600-800 hp setup, i have precision 6766 t4 divided 1,32 ar, i have a skunk 2 pro 1 that eated rocker and themselfs, only in first cilinder EX, i send a few emails for skunk they do not respond, i have a race soon, can anybody tell me if i can use ctr ex cam with pro 1 Intake cam? I will loose many power with setup? I want to make 40 psi.
Thanks In advance
Old Jul 10, 2013 | 01:01 PM
2k.civic.si's Avatar
Default Re: Skunk 2 Pro1 Problem
why not just run both the in and ex ctr cams?
Old Jul 10, 2013 | 01:08 PM
kissifur's Avatar
But with pro1 full setup make more power than ctr ones right?
Old Jul 10, 2013 | 02:45 PM
rs250nut's Avatar
What were the clearances set to? Don't **** around just use the type r cams, I'm sure they will make the hp you need.
Old Jul 10, 2013 | 05:03 PM
sheepey's Avatar
you bother checking if the LMA is bottoming out? That is NOT a cam problem, you either have LMA clearance issue or spring binding up...
Old Jul 10, 2013 | 07:47 PM
V-SPEC 1's Avatar
What motor oil are u using?
Old Jul 11, 2013 | 01:28 PM
kissifur's Avatar
Brad penn 10w40, i have almost 90 psi of oil pressure. I have supertech NA springs.
Bsharpe
May 21, 2010 09:47 PM
Bsharpe
Jan 24, 2010 02:38 PM
01DC4
Apr 1, 2007 06:38 PM
