Size difference between 6262 & 6268
Old Mar 12, 2012 | 01:46 PM
BlackArtsRacing's Avatar
Default Size difference between 6262 & 6268
Good evening gents,
A buddy of mine currently runs a 6262 with a .82 A/R on his SRT-4. He just got a smokin deal on a 6768 (also .82 A/R), but we are concerned about the 6768 fitting. For those of you who don't know, the turbo sits behind the engine between the engine and fire wall. I was wondering what the overall size difference between the two turbo's is.
Specs for the turbo's is:
-"S" compressor cover 4.0" inlet/2.5" outlet
- T3 .82 A/R with 3" V-Band discharge
Any info, links, etc will be greatly appreciated.
Old Mar 12, 2012 | 02:00 PM
Pumpking.'s Avatar
Default Re: Size difference between 6262 & 6268
Originally Posted by BlackArtsRacing
Good evening gents,
sorry i don't know the actual size difference (if any), but the 676x fits back there on the srt.
Old Mar 12, 2012 | 02:08 PM
Cool.
I guess that's all I really needed to know. Just wanted to provide as much technical info as I could. Thanks man.
Old Mar 12, 2012 | 03:44 PM
SPOOLINmatt's Avatar
if both turbos have the S cover than they are the same physical chassis and there should not be any problem.
Old Mar 12, 2012 | 03:59 PM
Thanks Matt!!! As Pumpking can tell you. Not a ton of room back there.
This pic shows the 6262 on a log manifold. the car will have a new tubular manifold from CTI in the near future, but turbo will still sit in the same general area.
Just wanted to post a pic to give you all a general idea.
Old Mar 12, 2012 | 05:01 PM
Pumpking.'s Avatar
i'm not exactly sure where the CTI manifold seats the turbo, but i'm guessing you will definately need to 'massage' the firewall a bit to get some clearance, as the S covers make for a tight fit. a little bit of denting itll clear no problem. Just make sure there is enough clearance for when the motor rocks back/forth from motor mount movement.
Old Mar 12, 2012 | 05:07 PM
boosted92snatch's Avatar
If theyre both the same t3 flange and a/r on the exhaust side and s cover on the intake side theyre exactly the same size ive owned both they were the same. Just the wheels are bigger
Old Mar 12, 2012 | 06:31 PM
Default Re: Size difference between 6262 & 6768
I just edited the title. I just noticed I had "6268" when I meant 6768. Looks like you guys understood what I meant, not what I said!
Well the 67mm is already purchased, so It's going on the car some how!!! the fire wall will probably get a good shalacking!!
Old Mar 12, 2012 | 09:55 PM
Hyper16-Johnny's Avatar
x2, make sure they're both t3's. Most 6768 are t4's so double check.
Old Mar 13, 2012 | 12:57 PM
Did Just that and got the same answer. Would either need to run a 6266 or 6766. We opted for the 6266. Thank god it had not been ordered yet!!
A new turbo had to be ordered to accomidate the new turbo kit. Getting rid of the old school log manifold and going with a CTI tubular. the new turbo will have V-band discharge vice the 4 bolt.
Thanks again guys!!
Old Mar 13, 2012 | 01:34 PM
Pumpking.'s Avatar
Thanks again guys!!
did your buddy have a dyno chart of his car w/ the 6262?
civic_k20a3
Jan 11, 2006 06:13 AM
Mr.DC2TurBo
Feb 15, 2004 07:24 AM
psycho_civic
Oct 16, 2003 02:41 PM
Spoold_R
Sep 12, 2003 08:13 AM
eddie1681
Mar 27, 2002 02:42 PM
