shooting for 12's
Old Dec 9, 2007 | 02:43 PM
sfwdcrx's Avatar
Default shooting for 12's
i am running a '91 crx si, with a stock b16a with a cheap t3t04e turbo on it pushing about 10 psi of boost. the tranny is a ys1 with lsd and 22/8/13 m&h slicks. i also live in colorado where corrected altitude can be almost 9000 feet on a bad day. so i guess my question is mid to high 12's realistic or not. thanks for the imput
Old Dec 9, 2007 | 04:02 PM
Redcoupe's Avatar
Default Re: shooting for 12's (sfwdcrx)
Depending on if your driving skills, and drivetrain setup. I can see 12s out of your car.
Old Dec 9, 2007 | 09:52 PM
japan4racing's Avatar
FWIW i ran 12.2@116 with a stock gsr in a dx 4 door with a peakboost 60trim kit on 10 psi and slicks
Old Dec 10, 2007 | 12:31 AM
My_EFsedan's Avatar
Default Re: (japan4racing)
my brother ran a 12.7 in his crx with stock NA b20vtec...
Old Dec 10, 2007 | 03:57 AM
715civic's Avatar
It’s a challenge for sure if you’re racing at Bandimere Speedway. I say mid -13 but who knows until you hit the track. Good luck.
Old Dec 20, 2007 | 10:45 AM
sfwdcrx's Avatar
Default Re: (715civic)
here are the specks on the turbo but no i am up in the air on how big of an injectors i should run, 3 INCH AIR INTAKE SIDE - 2 INCH EXHAUST EXIT SIDE - 30+ PSI CAPABLE
T3/T4 FLANGE FITTING - T04E HYBRID TURBO CHARGER - .57 COMPRESSOR WHEEL TRIM
.50 A/R COMPRESSOR - .63 A/R TURBINE
so any input no will help alot. thanks
J . K .
Dec 2, 2010 08:48 AM
b00stedOne
Nov 29, 2009 09:25 AM
yusoslo
Apr 27, 2004 07:03 AM
1dumbscreenname
Aug 5, 2003 11:00 AM
Poop111444
May 24, 2003 07:36 AM
