Shifting Tips?
Old Feb 19, 2009 | 06:21 PM
shutuprichard551's Avatar
Icon7 Shifting Tips?
Hey guys I finally got my car and have had it for about 2 months now. It was my first time driving stick, I got the hang of it now and im driving great, I just wanted to know if you guys had any tips to take my driving to the next level?
Old Feb 19, 2009 | 07:32 PM
Boostfed86's Avatar
Default Re: Shifting Tips?
practice.
Old Feb 19, 2009 | 08:28 PM
Well yeah I know that, but like at what RPM to you guys shift at? is there much of a benefit from a short shifter? and stuff like that.
Old Feb 19, 2009 | 08:37 PM
Roger Z06/Supra's Avatar
Banned
Don't double clutch lol, but get good and making a fast smooth shift without dropping the RPM's too low for entering your next gear. I do not know what RPM you honda people shift at, but it is usually where the little white lines turn into little red lines.
Old Feb 19, 2009 | 09:43 PM
ALLxMOTOR EG's Avatar
Vietnamese!
You actually learn on your own,cause i did
Old Feb 20, 2009 | 07:21 AM
boostedcivicsir's Avatar
Mr. Badwrench
shift when the car stops making power, and just get urethane shifter bushings. keep the stock lever.
Old Feb 20, 2009 | 07:28 AM
jlude90's Avatar
i don't know about you gm/yota people, but my engine redlines where the stock tack ends...1500rpm after the little white lines turn red
Old Feb 20, 2009 | 07:50 AM
acrite1999's Avatar
lol
Old Feb 20, 2009 | 08:14 AM
96 GSR-T's Avatar
I learned how to drive stick on a brand new 2000 ITR, just drive it and figure it out, not much else someone can tell you about it.
Old Feb 20, 2009 | 08:28 AM
Adankid's Avatar
lucky ****!
i hope that itr wasn't yours.
Old Feb 20, 2009 | 08:30 AM
96 GSR-T's Avatar
Originally Posted by Adankid
lucky ****!
Yea it was mine it had 11 miles on it, chirped the tires driving off the showroom floor, same tranny is still going today......
Old Feb 20, 2009 | 07:51 PM
srmofo's Avatar
Now , Now kids....behave
personally I thought this was funny
But as far as a shift pont goes, everycar is different. Yours is proly stock , so shift somewhere before redline....Its kinda a trial and error thing if the car has never been dyno'd and you dont know where it drops off at
Old Feb 20, 2009 | 08:46 PM
What about HARD LAUNCH, DOUBLE CLUTCH, SINGLE CLUTCH, and HEEL AND TOE?
(I have tryed a Hard Launch and cant seem to get it right)
Old Feb 20, 2009 | 08:48 PM
O and my car is a 97 civic Ex Coupe
Old Feb 20, 2009 | 08:49 PM
Banned
what about hard launch, double clutch, single clutch, and heel and toe?
(i have tryed a hard launch and cant seem to get it right)
facepalm
Old Feb 22, 2009 | 03:22 PM
Ls_dx's Avatar
"perfect practice makes perfect"
Old Feb 22, 2009 | 03:50 PM
SovXietday's Avatar
Well if you want to get all Car make profiling from what i hear and see you Honda people shift after about 6 bounces of the rev limiter. It is like waaaaaaaaaaa bamp bamp bamp bamp bamp bamp cacha(<--- shift noise) waaaaaa... lol
That's because when you're doing a clean burnout through 2nd and 3rd gear you need allow the car to actually make it to the shift speed in MPH. If you spin and just shift like normal the car will bog horribly.
Old Feb 22, 2009 | 06:56 PM
Honda Bull's Avatar
Hey SOHC you need to calm down a little bit... and obviously I was right about the shift point question before I "schooled" about going 1500 past the red for VTEC... so lets not be so critical about what people say and you E-stalking their every post
lol VTEC must be some sort of magical occurance for this guy. Glad we understand it's just a simple cam profile and the engine operates its power band exactly in coordination with it. Is this the same guy that was in the NSX forum causing some drama?
To the OP,
1. Get shifter bushings, keep the stock shifter like someone mentioned (unless you want another shifter).
2. Beat the hell out of it when you desire performance.
3. Be nice to the trans when you don't desire performance.
4. Replace synchros when necessary.
5. Repeat steps 2-4.
Old Feb 23, 2009 | 02:29 PM
Ls_dx's Avatar
Thats good stuff right there!!!!
Old Feb 23, 2009 | 08:39 PM
Boosted_B_Series's Avatar
Any tips on the gsr tranny's 1-2 shift? Boosted app..
I fall out of boost bad because the rpms drop so much..
Should I induce more wheel spin in 1st and try to keep it going in 2nd? I could be way off here
I've been considering flat footing it, or enabling fts.
Thanks for your time,
dk
Old Feb 28, 2009 | 10:00 PM
bump
Old Mar 2, 2009 | 05:02 PM
y.o. boosted eg's Avatar
dk
I have the same problem,1-2 gsr tranny,my car was droping from 9500 to 5800.
I just put a 3.07 1st gear in it so that with raising the limiter to 10,000 1-2 will be
around 6100, but still needs a littile more mid-range. more wheel spin helps LOL...
Old Mar 3, 2009 | 05:28 AM
wolve's Avatar
dk
shift faster and do not lift your right foot!
keep shifting faster untill it feels like an automatic.
once you reach full-throttle in first gear, there's no need to move your right foot except for excessive wheelspin.
some nonhonda people where shocked when they found out it was stick. they said it sounded like a automatic when i raced them. feels like too
this season i'll wire in the FTS for the ecu and have new carbon coated synchro's. so it should even more easy.
just start off with 1/2 throttle shifts and gradually lift less.
how much boost is your setup making on the dyno at 5800?
what's the setup?
Old Mar 3, 2009 | 05:29 PM
93 Eg Couper's Avatar
you shift whenever you want
if your driving slow in the city you shift low
for max speed in a honda you figure out where your rev limiter is and right that **** out everytime
Old Mar 3, 2009 | 06:53 PM
lee0149's Avatar
what's the setup?
dam this is what i called MAJOR POWER SHIFTING. Should this kill you tranny andclutch bad.
