Shifter Talk...
Old Mar 3, 2004 | 12:30 AM
slowsi00's Avatar
Default Shifter Talk...
i looking for a better smoother shifting setup than the one i have now. what does everyone use?
i have the b&m i dont like it that much.
i was looking into the skunk2 shift *** and shifter. i heard that really smooth and short. but i was also loking for a shifter that was a little taller to bring the shifter higher.
i heard improving the trans mounts helps out alot becasue then the trans won't move it will help u get a better shift.... is this true?
lookn to bang gears a little harder and more consistant in 2004
Old Mar 3, 2004 | 04:29 AM
SpeedDreamz.com's Avatar
Default Re: Shifter Talk... (slowsi00)
The shifter itself really has nothing to do with how smooth the shift is. Bushings, linkage and trans condition determine that.
Old Mar 3, 2004 | 08:44 AM
slowsi00's Avatar
Default Re: Shifter Talk... (30psiCiv)
we never talk abourt this in the drag racing forum.
its important imo.
u gotta be comfortable with your shifter.
Old Mar 3, 2004 | 09:23 AM
XLR8 GS-R's Avatar
[QUOTEThe shifter itself really has nothing to do with how smooth the shift is. Bushings, linkage and trans condition determine that. [/QUOTE]
Da man 30psi is right- the better performance comes with better bushings, shift linkage, and plain and simple- new factory (Honda) parts. If your parts are old, the performance is going to be old. Just like an old man, trying to race his ferrari. <-- (well, this actually has nothing to do with anything). But anywho- I have the skunk2, and where you heard it was the shortest?! Its actually stock height. The bearings are awesome, and yes, the shifting was far improved from the stock unit. I dont have the skunk2 ****, (the thing weighs like 10 pounds) but it does make for solid gear changes with the added weight while taking less effort to shift.
I dont know how B&M works, expect for the fact that they have a big name cooperation, and lots of $$- which dosent always make it be "a good product."
As far as tranny mounts go- yes- the more solid the better. Basically, the more your tranny shakes, the more your shifter is going to shake. As far as strengthining the stock unit I dont know how you would go about doing that unless you got custom fab done. I dont know of any aftermarket tranny shells/mounts? (eagle are you reading this)
I ripped my tranny right off the mount going from 1st to 2nd. The torque of the motor (on stock mounts) just tore it right off.
Old Mar 3, 2004 | 09:28 AM
slowsi00's Avatar
thanks for your input.
i am thinking about going with the full skunk2 package.
last year i had a stock tranny mount andb&m short throw(street version) and new bushings and i thought that the throw was short but so was the damn shifter.
this year i am looking at poly bushing insert for the trans and new shifter bushings and skunk 2 shifter and ****.
i heard that the gm syncromesh fluids also help out shifting tons as well
Old Mar 3, 2004 | 06:50 PM
slowsi00's Avatar
bump for more comments.
Old Mar 3, 2004 | 07:04 PM
JDM2ndGen's Avatar
Default Re: (slowsi00)
ive heard really good thinks about the skunk2 and the skunk2 shift **** combo ...i have a some no name shifter now ...but im looking to get the skunk2 combo ...
Old Mar 3, 2004 | 07:58 PM
drvfast's Avatar
i had the the skunk 2 short shifter and new bushings and it was a great setup. I would recommed the skunk 2 shifter. Its one of the shortest shifters out.
Old Mar 3, 2004 | 08:03 PM
Sliced Beard's Avatar
Default Re: (airshifta)
honestly i think you should just stick with a stock shifter and upgrade the bushings and get a good set of motor mounts and maybe a new set of syncros
Jared's Avatar
my favorite setup is a set of good motor mounts, the polyurethane shifter bushings from energy, and a stock GSR shifter.
Old Mar 3, 2004 | 08:15 PM
kid-honda's Avatar
I got a I dont remember the name soild short shifter with enrgy bushings, hasport motor mounts and when I made the linkage for the B series I welded the linkage so the shifter angles more towards the driver side.
Old Mar 3, 2004 | 08:48 PM
Spartanic's Avatar
Definitly upgrade your shifter busings to Energy Suspensions shifter stabilizer bushings. You'll notice an improvmnt in shifter feel. You can find it at http://www.jdmgears.com.
Old Mar 3, 2004 | 10:50 PM
slowsi00's Avatar
i am going with the skunk2 setup i think it looks better everyday.
Old Mar 4, 2004 | 02:50 PM
G-reX's Avatar
I'm using energy suspensions stabilizer bushings, which work well. And I use to use a APC crap for a shifter but last summer I switched to a JG Edelbrock shifter adn ****. I love it.
Old Mar 4, 2004 | 07:26 PM
no2psi's Avatar
I have Obsesive complusive disorder, when it comes to shifters, I have had several over the years, and always come back to a stock GSR, however the fastline shifter looks promising but $149.00 ouch!
http://www.fastlineperformance.com/shifter.htm
Old Mar 5, 2004 | 05:12 PM
JDM2ndGen's Avatar
Default Re: Shifter Talk... (no2psi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by no2psi &raquo;</TD></TR><TR><TD CLASS="quote">I have Obsesive complusive disorder, when it comes to shifters, I have had several over the years, and always come back to a stock GSR, however the fastline shifter looks promising but $149.00 ouch!
http://www.fastlineperformance.com/shifter.htm </TD></TR></TABLE>it does look really good ...but it says for road racing ...it would still make a good shifter even if you dont road race?
Old Mar 5, 2004 | 05:24 PM
2FastxEg's Avatar
yeah i would have to agree with some other peeps on this... the best in my opinion is the stock gsr shifter with a stock gsr shift ****, thats teh best feeling in my opinion......
Old Mar 5, 2004 | 07:00 PM
no2psi's Avatar
Default Re: Shifter Talk... (JDM2ndGen)
I dont know how it will work out, however I plan on getting one, and putting it in my street car. I will let you know, how it feels.
Old Mar 5, 2004 | 08:43 PM
99blackcivicSi's Avatar
on my coupe i have a GSR shifter with the bushings and it is great i love it.
Old Mar 6, 2004 | 07:04 AM
Tim the Stick's Avatar
only shifters Fastline has left are for Del Sol's I believe.
Mista Bone in Detroit
Old Mar 6, 2004 | 12:54 PM
no2psi's Avatar
Default Re: Shifter Talk... (Tim the Stick)
yea, i talked to Marcus at heel toe auto. They said that they are making another batch.
Old Mar 6, 2004 | 06:18 PM
fasthatch82's Avatar
i've heard the ITR shifter is the best short shifter you can get. I personally had a generic 3A racing shifter from pep- boys with energy suspension bushings and hasport mounts and I couldn't ask for a better shift.
Old Mar 7, 2004 | 08:16 AM
JDM2ndGen's Avatar
Default Re: (fasthatch82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by no2psi &raquo;</TD></TR><TR><TD CLASS="quote">I dont know how it will work out, however I plan on getting one, and putting it in my street car. I will let you know, how it feels.</TD></TR></TABLE>cool thanks let me know ...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fasthatch82 &raquo;</TD></TR><TR><TD CLASS="quote">i've heard the ITR shifter is the best short shifter you can get. I personally had a generic 3A racing shifter from pep- boys with energy suspension bushings and hasport mounts and I couldn't ask for a better shift.</TD></TR></TABLE>i was thinking about using a ITR shifter for a while ...i talked t a few people that used them and they liked them...
Old Mar 8, 2004 | 02:48 AM
Mista Bone's Avatar
D Tranny Guru
Marcus might be trying to get Greg to make another batch, but I doubt it will happen, We'll see.
Old Mar 8, 2004 | 04:20 AM
GSRswapandslow.
Guest
Posts: n/a
i have an ITR shifter, i've had sevarl cheap-o's, a skunk2, and a stock GSR...but right now i have a hurst...and I actually like it a lot. it's pretty tall which is kinda cool
ohh, and i HATE my skunk2 shift ****...with a passion...i'm loving my 6 speed, old *** civic **** though (mint condition too )
