Sfwd 160+ input
Old Aug 18, 2013 | 05:41 PM
94turbosi's Avatar
Default Sfwd 160 + mph brake set up
Looking for some advice on brake set up , I currently have a 00 civic si with gsr brakes all around I'm in the market to delete the factory booster , I've read and searched there are alot of mixed opinions, looking for actually people that are going 160 + what size master should be used ? Front brakes only or use stock proportion valve with aftermarket master ?
Old Aug 18, 2013 | 07:23 PM
Zer0_SpeedWorks's Avatar
Default Re: Sfwd 160+ input
Kkc boosterless setup,gsr calipers with ebc redstuff pads im on all 4brakes..
Old Aug 19, 2013 | 03:40 AM
94turbosi's Avatar
Do you happen ton know what size you're cylinder is on your master ? And you're still using your stock proportion valve ? Thanks for your input.
Old Aug 19, 2013 | 04:21 AM
Yes im still on my oem prop valve... Im switching to mark williams front brakes this season and i was told by them to run the same size master. Ill look later and update you.
Old Aug 20, 2013 | 06:39 PM
94turbosi's Avatar
Anyone else care to share there brake set up ?
Old Aug 20, 2013 | 06:49 PM
Garage 808 Hatch's Avatar
I was lighter weight, but just had good rotors and pads up front. rears were just on the staging brake.
blue1.6eg
Suspension & Brakes
23
Feb 15, 2016 03:21 AM
X93siX
Suspension & Brakes
Aug 15, 2012 10:55 PM
RC211V
Dec 14, 2005 01:17 PM
TEGPOWER44
Sep 8, 2003 04:19 PM
bruvaman
Jul 9, 2002 07:19 PM
