Setting alignment for best traction:
Old Dec 6, 2007 | 11:13 PM
THE GAME IS THICK's Avatar
Default Setting alignment for best traction:
is there a rule of thumb when setting alignment on a drag car? should it just set to stock specs for best use on slicks? i know that if there is any positive or negative toe the tires will be fighting each other. can anyone elaborate more on this?
Old Dec 7, 2007 | 02:53 AM
1992Si's Avatar
I would think you'd want the slicks flat on the track when the weight is transfered. Look at some photo's of cars before and during the burnout box and launching.
I'd give you more, but it's not my place to give away someones secrets.
Old Dec 7, 2007 | 06:30 AM
Sage972's Avatar
Default Re: (1992Si)
I thought that is what honda-tech was for is helping people....
Old Dec 7, 2007 | 06:37 AM
teamXXXrob's Avatar
Teamxxxracing.com
Default Re: (Sage972)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sage972 &raquo;</TD></TR><TR><TD CLASS="quote">I thought that is what honda-tech was for is helping people....</TD></TR></TABLE>
thats what all forums are for or at least supposed to be for. If i had the answer, i'd give it to you man.
Old Dec 7, 2007 | 06:46 AM
miller's Avatar
Default Re: (teamXXXrob)
this topic has been covered before plenty of times.
Think about the way the car reacts and drives down the track. Use your brain to figure it out. "Honda-tech"isnt gonna tell you everything.
Old Dec 7, 2007 | 10:11 AM
jpenman50's Avatar
Default Re: (miller)
you need to look into how much suspension travel you have and adjust your setup accordingly to that... alot of people are making there cars work very well with different suspension setups... Again look into the amount of travel you have... If you have no pics of the car you can get an idea by lifting the front of the car and seeing how much the front suspension droops... Make sure you have a good set of upper control arms... For full adjustment.. Align the car to where the slick is going to be flat at full suspension travel... (use an alignment rack!!!!!)
Old Dec 7, 2007 | 10:58 AM
Brent L's Avatar
Also Look into getting your bump steer set up then the wheels will always travel straight
regardless of suspension movement
Old Dec 7, 2007 | 04:46 PM
94turboeg's Avatar
Default Re: (Brent L)
Stock alignment has worked better for me .Then the other stuff I`ve tired.
Old Dec 7, 2007 | 10:11 PM
Default Re: (94turboeg)
thanks for everyones input. Im mainly doing some research for my friends evo 8 and some for myself as well. The evo will be on NT555R's and i will be setting his alignment for him (i work at a shop) once we get those stickier tires on there. i figured i would post on here since this site is a lot more active than most. I will have to do some research more on his car before i start adjusting. more than likely i will just set to as stock as possible and close to zero degrees of camber and toe.
Old Dec 12, 2007 | 08:41 PM
JakeSpec's Avatar
Default Re: Setting alignment for best traction: (THE GAME IS THICK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THE GAME IS THICK &raquo;</TD></TR><TR><TD CLASS="quote">is there a rule of thumb when setting alignment on a drag car? should it just set to stock specs for best use on slicks? i know that if there is any positive or negative toe the tires will be fighting each other. can anyone elaborate more on this?</TD></TR></TABLE>
let me give it a shot,,
setup the car on desired Tires take it to get aligned
set toe 1/8 negative on both wheels and camber -1 degrees i think thats right
so when the car launches the wieght distributes and lifts the front Perfect camber and the chassis will flex bringing the toe in a perfect alignment and setting the slick level with the ground
works for me!
Old Dec 12, 2007 | 08:59 PM
redboost10's Avatar
Default Re: Setting alignment for best traction: (JakeSpec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JakeSpec &raquo;</TD></TR><TR><TD CLASS="quote">
works for me!</TD></TR></TABLE>
what suspension are you running? just wondering
Old Dec 12, 2007 | 11:21 PM
thanks for chiming in. i was lookin at your sig and saw 7.33! thought it was 1/4 mile for a second there.
i work at a shop so i will be doing the alignment on the evo 8 and my own car myself so i will give it a shot. the evo already pulls 1.61 60 ft's but we all know on the street its a different story. not saying that i street race. ahem...
Old Dec 13, 2007 | 06:18 AM
JakeSpec's Avatar
Default Re: Setting alignment for best traction: (redboost10)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redboost10 &raquo;</TD></TR><TR><TD CLASS="quote">
Function and Form 800Lb Front 1000Lb Rear with Cusco Sway's and Cusco Rear CrossMember Bar
Old Dec 14, 2007 | 04:05 AM
Da Moose's Avatar
Here you go 0 degrees chamber, 7-8 degrees of positive caster, and about 1/8 to 1/4 of toe out.
Old Dec 14, 2007 | 05:35 AM
SPOOLINmatt's Avatar
Default Re: Setting alignment for best traction: (Da Moose)
heres one. Should i align the front with the slicks at about 30 psi of tire pressure since when the car is going down the track the tire grows to near the same size as fully inflated from expansion.
Old Dec 14, 2007 | 09:34 AM
Da Moose's Avatar
Default Re: Setting alignment for best traction: (SPOOLINmatt)
No set alignment with what ever pressure you set them at the starting. And make sure when ever you make an allignment adjusment you roll and jounce the car before taking the next measurment. because the tires are so soft you will move the rim in the tire, and be fighting yourself all day.
Old Dec 15, 2007 | 08:32 AM
something doesnt sound right about that.
Old Dec 16, 2007 | 04:52 PM
ExecutiveA's Avatar
is that for any setup? or only 4wd?
Old Dec 16, 2007 | 05:04 PM
ciscoscivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brent L &raquo;</TD></TR><TR><TD CLASS="quote">Also Look into getting your bump steer set up then the wheels will always travel straight
regardless of suspension movement</TD></TR></TABLE>
Old Dec 16, 2007 | 05:09 PM
JSpin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOOLINmatt &raquo;</TD></TR><TR><TD CLASS="quote">heres one. Should i align the front with the slicks at about 30 psi of tire pressure since when the car is going down the track the tire grows to near the same size as fully inflated from expansion. </TD></TR></TABLE>
Old Dec 16, 2007 | 05:11 PM
PremierS372's Avatar
works for me!
This is close to the spec I use and works great for me.
Old Dec 16, 2007 | 06:27 PM
JakeSpec's Avatar
Default Re: Setting alignment for best traction: (JSpin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSpin &raquo;</TD></TR><TR><TD CLASS="quote">
no make sure your inside the car and drop your Psi down to your normal run setting
Old Dec 16, 2007 | 08:52 PM
DelSolstice's Avatar
if it ain't broke....DON'T expletive IT UP!!!!
fcuk.hollywood
Jun 26, 2006 07:53 AM
megotvtec
Apr 12, 2005 10:03 AM
93LSivic
Dec 13, 2004 11:09 AM
99lspwr
Jul 1, 2003 05:19 AM
flastreetscn
Mar 7, 2003 12:28 PM
