s300 with C02 possible???
Old Sep 26, 2011 | 06:08 PM
sgnlab's Avatar
Default s300 with C02 possible???
Can I just hook up a c02 setup to my solenoid? What goes into a c02 setup???
I keep having a boost issue with a car and need to try to figure it all out...
Old Sep 26, 2011 | 06:17 PM
SynTeg's Avatar
Default Re: s300 with C02 possible???
Yes. All you need co2 bottle,regulator, and push lock fittings/hoses.
Old Sep 26, 2011 | 06:37 PM
TheWickedOne's Avatar
Its really not necessary for what you're doing. Manifold pressure works fine. Its all about having the right base spring pressure.
Old Sep 27, 2011 | 09:00 AM
locash's Avatar
Or the right amount of backpressure.
Old Sep 27, 2011 | 05:40 PM
95exdsmkilla's Avatar
can you please explain when would it be necessary using c02 boost controller?
Old Sep 27, 2011 | 06:06 PM
In my opinion
Pros:
  • Consistency of of applied pressure on top of the Wastegate diaphram
  • Ability to run a very light wastegate spring and have the ability for high psi. "Wide Range of pressure"
  • To answer your question BIG Boost.. if needed, and if you have a turbo to even support it.
Cons:
  • Possibility of tearing Wastegate Diaphrams," yes it can happen"
  • Leaks
  • Refilling bottle
  • Forgetting to turn on the bottle before a run
  • Forgetting to turn off the bottle with a leak in the line
More of a hassle in my opinion, with a properly sized wastegate spring etc. You can run lots of boost, more than 98% of us will ever really need.
Old Sep 27, 2011 | 09:20 PM
Muckman's Avatar
Moderator in Chief
What kind of boost range are we talking about here?
Old Sep 27, 2011 | 11:36 PM
hello1320's Avatar
5-50+
Old Sep 28, 2011 | 03:39 AM
bamboosted's Avatar
In my opinion
Pros:
Cons:
  • Leaks
  • Refilling bottle
What size spring did you use to run? You were also divided ? This partciular car is running 1-60mm
Old Sep 28, 2011 | 04:55 AM
zakura R's Avatar
!!!!!Some one is doing the home work early !!!!!
Old Sep 28, 2011 | 07:14 AM
Bugermass's Avatar
One of the cars I tune has a 8 psi spring and we've held 55PSI on it with no CO2.. Your just over complicating your setup..
Old Sep 28, 2011 | 07:23 AM
Enzo-Racing's Avatar
with large turbos on small engine's (4 cyl) backpressure usually is not an issue and you can run with manifold pressure alone. On some large v8 engines backpressure is alot greater and most guys need to use C02 in order to get big boost... Although realistically they should just upgrade their turbos instead.
Old Sep 28, 2011 | 08:48 AM
Bugermass's Avatar
If your in a situation where your backpressure is high enough to blow your gates open you probably shouldn't be trying to add more boost. .
sgnlab's Avatar
this is way over your head mr. fake 9.1 @ 165mph go blow another motor will ya!
Old Sep 28, 2011 | 09:00 AM
sgnlab's Avatar
Either way this car will not climb past 34-35 psi on the track we can get it to hit 45psi on the dyno with out any problems but once at the track she wont go past 34-35psi.
We have an 11psi spring in the wastegate
60mm tial wg
the manifold is divided with only one 60mm gate
Hondata S300 with mac valve
air to water IC 1,000 hp core
The source for the wastegate is coming from the compressor cover
I have tried to remap the duty cycle settings @ the track from my datalogs
What I have not done is added the diode to the mac valve which I am going to do tomorrow. I am also looking into getting a new mac valve and a bigger base pressure spring.
The car is running a BW S372r with 1.25ar turbine.
Old Sep 28, 2011 | 09:37 AM
Thats not cool dude, Hope you don't Jinx yourself.
Old Sep 28, 2011 | 09:38 AM
60mm tial wg
So whats the duty of the solenoid at 35 psi ?
Old Sep 28, 2011 | 10:30 AM
zakura R's Avatar
Icon6 Re: s300 with C02 possible???
Tsk tsk tsk tsk lol
Old Sep 28, 2011 | 11:03 AM
Bugermass's Avatar
60mm tial wg
try pulling your wastgate source from the manifold. You probably are making MORE boost pre intercooler then you are at the manifold so your gates are opening early. Try pulling it from the manifold and see if it helps.. It not then you have another issue somewhere, either backpressure a boost leak.
forgot I read this couple months ago and completely forgot...
https://honda-tech.com/forums/showth...&highlight=c02
Old Sep 28, 2011 | 11:08 AM
I've been doing this homework for a month now, just trying to perfect the system. but i think s300 have its own limits when it comes to c02 or boost controller it self...
In MY opinion.
but hey what do i know im still new to the scene lol.
Old Sep 28, 2011 | 11:53 AM
sgnlab's Avatar
Tsk tsk tsk tsk lol
Wow this is all you have to add to the thread? Told you it was over your head.
Old Sep 28, 2011 | 12:01 PM
bads2k's Avatar
I've noticed with C02 it holds the set boost more consistant and also makes the set boost faster. Without it I noticed boost creep up slower and drop off a little at a time
Old Sep 29, 2011 | 06:32 AM
4g63-s2k's Avatar
I've always heard you can only run 3 times what the wastegate spring is, so if you have an 11 psi spring, it should max out in the 30s but I could be wrong, if u need some springs I have some extra ones u can have
Old Sep 29, 2011 | 08:04 AM
Muckman's Avatar
Moderator in Chief
Ive run 8x spring with a 4 port solenoid.
Kid-jdm-teggy
Feb 25, 2014 02:24 PM
hyboost
Jul 3, 2009 05:54 PM
Jared
Feb 27, 2006 07:25 PM
Duck Sauce
Aug 10, 2002 08:00 PM
