running a harness ???????
Old Feb 11, 2004 | 11:51 AM
JusT a Cx's Avatar
Default running a harness ???????
befor i go and buy a $135 takata harness.....because its four point,do i need a cage to have it bolted right or can i just run it like you would run a 3point to the back seat, seat belt holes???
Old Feb 11, 2004 | 11:55 AM
PM-Performance's Avatar
Default Re: running a harness ??????? (JusT a Cx)
depends on how fast your going and where your racing . i have had them let me go before with a similar set up , but its an on or off thing. hard to say . try it , if it dont work keep your stock belts in there too , or just put a cage in it then
Old Feb 12, 2004 | 12:06 PM
JusT a Cx's Avatar
Default Re: running a harness ??????? (itr206)
any one know if a 4point harness will work without a cage ??
Old Feb 12, 2004 | 01:37 PM
Kataku2K3's Avatar
Yea you can make it but you can't really just run the upper straps straight down to the floor (angle isn't correct)... They would probably have to bolt to the rear seatbelt points... We don't ever do this (always go to the cage) so I'm not sure on the degree if you're planning on racing and being legal... Just my $0.02
Old Feb 12, 2004 | 04:50 PM
JusT a Cx's Avatar
Default Re: running a harness ??????? (Kataku2K3)
thanxz..thats what i wanted to know
Old Feb 12, 2004 | 05:01 PM
dmotoguy's Avatar
you should ask this in the road race forum and see what they have to say..
SovXietday
May 9, 2011 08:23 PM
V-SPEC 1
May 11, 2008 07:33 PM
B33R
Mar 3, 2006 10:46 AM
HondaMang
Nov 11, 2004 02:00 PM
Blindstuff
Feb 8, 2004 02:34 PM
