Rules for a parachute???????
Old Jan 28, 2008 | 05:26 AM
JBLAZE622's Avatar
Default Rules for a parachute???????
what are the rules as far as ET/ MPH where i'm gonna need a chute and a 10 pt cage i have a 8pt cage now so i just need 2 add on now if i run 135mph or faster but still in the 10's do i need the 10pt cage and chute or just the chute ??
Old Jan 28, 2008 | 05:49 AM
DaveF's Avatar
Default Re: Rules for a parachute??????? (JBLAZE622)
im pretty sure you need a chute @ 150mph.
10pt @ 9.99 or 135
Old Jan 28, 2008 | 05:57 AM
JBLAZE622's Avatar
Default Re: Rules for a parachute??????? (DaveF)
so the chute just depends on the MPH???
Old Jan 28, 2008 | 06:02 AM
2 0 3's Avatar
Yes. Chute is based on MPH. 10pt and window net @ 9.99/135
If you paying someone to do the 10pt conversion along with a window net, might as well have them do the chute mount too.
You dont have to actually buy the chute or bolt it on untill 150mph et's but atleast the anchor and tug bar are there... thats the way i would look at it.
Old Jan 28, 2008 | 06:10 AM
most_hated_crx's Avatar
Default Re: Rules for a parachute??????? (2 0 3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2 0 3 &raquo;</TD></TR><TR><TD CLASS="quote">Yes. Chute is based on MPH. 10pt and window net @ 9.99/135
i knew the window net was required at 9.99 or faster, but i didnt know you needed it for 135+
can someone confirm this?
Old Jan 28, 2008 | 06:26 AM
Evile140's Avatar
Default Re: Rules for a parachute??????? (most_hated_crx)
Sorry to get even more off topic, but what about arm restraints? My local 1/8th track sad they could be used instead of a window net. Any truth to this? Not sure if my car will ever hit 135+ but it is going to be a scary ride either way.
Old Jan 28, 2008 | 06:44 AM
DaveF's Avatar
Default Re: Rules for a parachute??????? (Evile140)
we have never used arm restraints on our 8 second car.
the only time ive ever seen arm restraints used was on my fathers dirt track modified. (non drag)
imo, using the armrestraints would be more of a pita then cliping in the window net.
Old Jan 28, 2008 | 06:54 AM
Honda Bull's Avatar
I think the need for a chute has even been reduced mph-wise. I'll check on that later today if someone doesn't confirm it.
SpeedDreamz.com's Avatar
how you gonna shift with an arm restraint?
Old Jan 28, 2008 | 06:57 AM
DaveF's Avatar
Default Re: Rules for a parachute??????? (SpeedDreamz.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedDreamz.com &raquo;</TD></TR><TR><TD CLASS="quote">how you gonna shift with an arm restraint? </TD></TR></TABLE>
lol. very good point, i didnt think of that. lol
on the dirt car, there is only 2 gears, you can put it into low gear with the car not moving(it wont move till you bump the "clutch" pedal.... the "clutch" is just used to move the car, then you jam it into high gear and thats it.
Old Jan 28, 2008 | 07:25 AM
2 0 3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by most_hated_crx &raquo;</TD></TR><TR><TD CLASS="quote">
can someone confirm this?</TD></TR></TABLE>
From BOTI 08 Rules :
Roll bar mandatory in all vehicles running
11.49 or quicker; roll cage mandatory in any car running 9.99 or quicker or 135 mph or faster. Non-OEM tubing in front of firewall prohibited
except to tie shock towers to roll cage. Roll cage in cars running
9.99 or quicker must be inspected every three years by NHRA and have serialized sticker affixed to roll cage before participation.
Wich is the same as NHRA 07 rules...
Anytime a roll cage is needed, so is a window net. There is no specific rule for the window net itself that i know of.
Old Jan 28, 2008 | 08:40 AM
JBLAZE622's Avatar
so how do i get the cage inspected ?? do i just go 2 the track and there is osmeone there 2 do it??
Old Jan 28, 2008 | 09:08 AM
2 0 3's Avatar
Default Re: Rules for a parachute??????? (rota92)
I would deff consider. When i dropped the car off, they had a few cars that needed certs. I think Tom was trying to get a cert guy there, in that case mine would be one of those cars. If not, then yea lets see how many more we can round up too.
OP is from CT! Yo man get that cage done so you can cert with us
Old Jan 28, 2008 | 09:32 AM
JBLAZE622's Avatar
def i'm actually going 2day to talk 2 a shop to add on to the 8pt i alreday have i'll let u guys know thanks...
Old Jan 28, 2008 | 01:35 PM
FRernesto's Avatar
Correct me if I'm wrong but the 10 PT is needed in a vehicle if the fire wall and frame have been modified. In order to go 9.99 or faster regardless of MPH.
Old Jan 28, 2008 | 01:38 PM
FRernesto's Avatar
When do I need a roll bar or roll cage, and what should it look like?
A roll bar is required in any convertible running 13.49 seconds or quicker in the quarter mile, and in other cars beginning at 11.49. The roll bar is accepted in vehicles running as quick as 10.00 second e.t., provided the stock firewall and floorboard is intact, other than for installation of wheel tubs. The rollbar must be constructed of minimum 1¾ inch o.d. x .118 inch wall mild steel tubing, or 1¾ x .083 chrome moly tubing. If the floor and/or firewall has been modified, then a full roll cage is required beginning at a 10.99 e.t. A full roll cage is required in any vehicle running 9.99 seconds or quicker, and any vehicle running 135 mph or faster (regardless of e.t.). The roll cage must be constructed of minimum 1 5/8 o.d.x .118 mild steel tubing, or 1 5/8 x .083 chrome moly tubing, and must conform to the following diagram:If the floor and/or firewall has been modified, then a full roll cage is required beginning at a 10.99 e.t. A full roll cage is required in any vehicle running 9.99 seconds or quicker, and any vehicle running 135 mph or faster (regardless of e.t.). The roll cage must be constructed of minimum 1 5/8 o.d.x .118 mild steel tubing, or 1 5/8 x .083 chrome moly tubing.
Old Jan 28, 2008 | 01:42 PM
tepid1's Avatar
I need my car certed too!
I'm in for a cert day.
Just let me know fella's
Old Jan 28, 2008 | 02:27 PM
JBLAZE622's Avatar
Default Re: Rules for a parachute??????? (tepid1)
made the appt for the cage to get finished on FEB8th how do they cert the cage??? just check over the welds or what ?? also whats involved in getting a NHRA license ??
Old Jan 28, 2008 | 03:08 PM
TheWickedOne's Avatar
For you New Englanders, Call Diamond R.V. in MA, They hold NHRA Cage Certification sessions there. Give them a ring and ask them when the next NHRA Cage/chassis session is.
They go over the welds/points/material thickness - They don't really care for the window net in., and bring a check book or cash. Be there early, first come first serve, as the lot gets pretty crowded
Edit: Whoops didn't see Rotas post.
Old Jan 28, 2008 | 03:13 PM
tepid1's Avatar
Default Re: Rules for a parachute??????? (TheWickedOne)
Good info Garry and Ryan. Thanks.
Old Jan 28, 2008 | 03:24 PM
tepid1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 &raquo;</TD></TR><TR><TD CLASS="quote">I'll make a call tomorrow if you guys want, we can see when their next one is. If it's too far off, or too close I can try to get one started for us.</TD></TR></TABLE>
Old Jan 28, 2008 | 03:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JBLAZE622 &raquo;</TD></TR><TR><TD CLASS="quote"> also whats involved in getting a NHRA license ??</TD></TR></TABLE>
Assuming a 9sec License?
First off get your physical and bring all the forms with you to have it filled out by the naughty nurse or Doctor. Don't get your physical too early, The first year of your membership starts on the date you get your physical (I could be wrong)
Then head to the track
1 Half Pass
3 Moderate Passes
2 9 Second Passes
1 Blindfold test
All passes need to be signed off by Track Manager and 2 other licensed drivers.
" If you guys need someone to go up and sign, I'll sign"
You do not have to do all the runs in one day, although tracks such as Lebanon Valley, When you register with them, and tell them your doing license passes they'll get you in before other lanes(pretty much whenever your ready) so you might be able to fit them all in.
Runs can be made on Saturday and Sundays. No Wed. Night Street nights.
http://www.nhra.com/contacts/forms/licenseapp.pdf
Modified by TheWickedOne at 9:23 PM 1/28/2008
Old Jan 28, 2008 | 05:18 PM
SockEG6's Avatar
ok stupid question...
blindfold test. what is that or are you making a joke?
Old Jan 28, 2008 | 05:24 PM
tepid1's Avatar
Default Re: Rules for a parachute??????? (SockEG6)
No joke. You need to know where everything is in the car. All switches and safety mechanisims.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SockEG6 &raquo;</TD></TR><TR><TD CLASS="quote">ok stupid question...
blindfold test. what is that or are you making a joke? </TD></TR></TABLE>
cockpit orientation test
