Rules about battery mounted in trunk???
Old Oct 31, 2003 | 05:19 PM
NirVTEC's Avatar
Default Rules about battery mounted in trunk???
I am having the battery mounted in the trunk with a Summit Racing relocation kit. Someone said that if you have a battery mounted in the trunk, you have to have an external shut offfor drag racing. Anyone know anything about this? Is there a way around having a HUGE silly on/off switch in the rear? Is it maybe a state by state or track by track basis?
Thanks in advance,
-clint
Old Oct 31, 2003 | 05:30 PM
ProstockH22crx's Avatar
Default Re: Rules about battery mounted in trunk??? (NirVTECn2o)
It's mandatory at any track.
Old Oct 31, 2003 | 05:31 PM
NirVTEC's Avatar
Default Re: Rules about battery mounted in trunk??? (ProstockH22crx)
Well....I'll just have to go to the 1 track I know that does a fly-by tech inspection until I get the switch.
Summit would probably have it?
Old Oct 31, 2003 | 05:51 PM
Yes summit does have it. Jegs.com also has em.
Old Nov 1, 2003 | 09:58 AM
martini's Avatar
you might also want to look into the NHRA rules, because some of those ones they sell at jegs or summit aren't NHRA legal.
Old Nov 1, 2003 | 10:01 AM
NirVTEC's Avatar
Default Re: Rules about battery mounted in trunk??? (martini)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by martini &raquo;</TD></TR><TR><TD CLASS="quote">you might also want to look into the NHRA rules, because some of those ones they sell at jegs or summit aren't NHRA legal.</TD></TR></TABLE>
Yup...I noticed that when I was looking for them.
Thanks guys!
Old Nov 1, 2003 | 12:11 PM
DaveF's Avatar
i have my battery mounted in the front of my car...do i still need to put an emergency shut off on the rear of my car????
Old Nov 1, 2003 | 02:45 PM
racerxadam's Avatar
Default Re: Rules about battery mounted in trunk??? (2.2Lcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2Lcivic &raquo;</TD></TR><TR><TD CLASS="quote">i have my battery mounted in the front of my car...do i still need to put an emergency shut off on the rear of my car????</TD></TR></TABLE>
technically it says any relocated battery and any car running 9.99 or faster has to have a switch.
Old Nov 1, 2003 | 03:50 PM
NirVTEC's Avatar
Default Re: Rules about battery mounted in trunk??? (racerxadam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racerxadam &raquo;</TD></TR><TR><TD CLASS="quote">
technically it says any relocated battery and any car running 9.99 or faster has to have a switch. </TD></TR></TABLE>
IT???
Old Nov 1, 2003 | 03:53 PM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NirVTECn2o &raquo;</TD></TR><TR><TD CLASS="quote">
IT???</TD></TR></TABLE>
the nhra rulebook
http://www.nhrasportcompact.com
Old Nov 2, 2003 | 06:51 AM
racerxadam's Avatar
Sorry, i thought will the NHRA rule book talk above you could USE CONTEXT to realize where i was getting the info
Old Nov 2, 2003 | 07:23 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Any car that traps 135+ has to have a cut-off switch regardless of where the battery is mounted dave, so its safe to say u need one, some day
Old Nov 2, 2003 | 11:51 AM
DaveF's Avatar
Default Re: Rules about battery mounted in trunk??? (SIXTYdashONE)
ill have to order it and put that bad boy in..i cant be going to races and not be able to pass tech.
thanks guy's
-dave
Old Nov 2, 2003 | 04:16 PM
racerxadam's Avatar
it was eluded to higher up but make sure you get a switch that can kill the alternator as well as the battery, if you are running an alternator.
Old Nov 3, 2003 | 07:45 AM
NirVTEC's Avatar
Sorry, i thought will the NHRA rule book talk above you could USE CONTEXT to realize where i was getting the info</TD></TR></TABLE>
sORRY.....Brain wasn't working very well!
Old Nov 3, 2003 | 08:33 AM
old guy's Avatar
This involves a little more work, but end result is slick. Use the standard kill switch that has the big "bat handle" on it, turns left or right. Mount in inside the car, "sideways" so that the handle actually moves forward or backward. (Keep reading). Pick up an extra tail light assembly for your car. Drill a hole through the tail light assembly, and fabricate a rod that goes through the hole and attaches to a hole you drilled through the top of the handle on the switch. From the outside of the car, you pull the rod to turn on the power, push the rod to turn off. When you're done at the track, go home and remove the rod, switch tail lights, and your're clean for the street again. You can even permantly mark your "racing" tail light with "PUSH - OFF" and the tech inspectors will be happy as hell.
Hope that made sense, I haven't had my coffee yet.
Old Nov 3, 2003 | 08:59 AM
Austin's Avatar
Default Re: Rules about battery mounted in trunk??? (old guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old guy &raquo;</TD></TR><TR><TD CLASS="quote">This involves a little more work, but end result is slick. Use the standard kill switch that has the big "bat handle" on it, turns left or right. Mount in inside the car, "sideways" so that the handle actually moves forward or backward. (Keep reading). Pick up an extra tail light assembly for your car. Drill a hole through the tail light assembly, and fabricate a rod that goes through the hole and attaches to a hole you drilled through the top of the handle on the switch. From the outside of the car, you pull the rod to turn on the power, push the rod to turn off. When you're done at the track, go home and remove the rod, switch tail lights, and your're clean for the street again. You can even permantly mark your "racing" tail light with "PUSH - OFF" and the tech inspectors will be happy as hell.
Hope that made sense, I haven't had my coffee yet.</TD></TR></TABLE>
I've seen that before, it looks quite nice and is very functional on a street based car.
Jim...did you get my phone call last week?
Austin
Old Nov 3, 2003 | 11:07 PM
vw16vcabby's Avatar
Default Re: Rules about battery mounted in trunk??? (Austin)
also keep in mind that teh black "marine" boxes that summit sells are not track legal. the morosso battery box is the only legal box because it "seals" the battery- in addition to having a vent tube that u run outside the car via drilling a hole. i ran into this b.s. when i ran the cheapo summit relocation kit. had to make a tin firewall to pass tech. then said f-it and bought the morosso box and ripped out the tin firewall.
however, if u have a gell &lt;sp?&gt; battery, i believe u can get around this.
also, if u hook up the kill switch, and it don't kill the car b/c of the alternator, run a wire from the kill switch straight to the alternator.
hth
Old Nov 4, 2003 | 02:00 PM
Austin's Avatar
Default Re: Rules about battery mounted in trunk??? (boostedgirlscar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedgirlscar &raquo;</TD></TR><TR><TD CLASS="quote">...snip...
...snip...</TD></TR></TABLE>
Nope, regardless of which battery you have, it must be vented. At least that's what I remember of the rules, and I've sat down and read the entire rule book.
Austin
Old Nov 5, 2003 | 11:30 AM
Mr Hammond's Avatar
a/k/a Jomo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Austin &raquo;</TD></TR><TR><TD CLASS="quote">
Austin</TD></TR></TABLE>
Correct "Gel-Cell" batterys still must be vented. Like Optima's etc....
Old Nov 19, 2003 | 08:14 AM
JICEK9's Avatar
Default Re: Rules about battery mounted in trunk??? (Mr Milano)
so the kill switch must be in the drivers reach??
Old Nov 19, 2003 | 09:18 AM
sircrxracer's Avatar
Default Re: Rules about battery mounted in trunk??? (JICEK9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JICEK9 &raquo;</TD></TR><TR><TD CLASS="quote">so the kill switch must be in the drivers reach??</TD></TR></TABLE>
No it has to be in the back of the car somewhere. Rob
Old Nov 19, 2003 | 09:49 AM
JICEK9's Avatar
Default Re: Rules about battery mounted in trunk??? (sircrxracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sircrxracer &raquo;</TD></TR><TR><TD CLASS="quote">
No it has to be in the back of the car somewhere. Rob</TD></TR></TABLE>
oh. ok thank you "sir"
Old Nov 19, 2003 | 10:32 AM
Austin's Avatar
That's actually a road racing rule if I remember correctly.
Austin
Old Nov 19, 2003 | 04:17 PM
80884's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedgirlscar &raquo;</TD></TR><TR><TD CLASS="quote">the morosso battery box is the only legal box because it "seals" the battery- in addition to having a vent tube that u run outside the car via drilling a hole. </TD></TR></TABLE>
taylor cable also makes a legal one, NHRA legal, aluminum box, sealed, vent tube included. also 3/8 mounting bolts too.
http://www.taylorvertex.com/batkits.html
very nice piece, i have one for myself
