roll cages
Old Feb 21, 2003 | 09:07 PM
vegan_punk's Avatar
Default roll cages
For going under 11.99 you have to have a 5 point but does it have to be welded. What about for a 6 point. DO they have to be welded to be legal?
Old Feb 21, 2003 | 09:39 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: roll cages (vegan_punk)
Its 4pt for 11.99 and under. and 5pt for 10.99 and under.. any bolt on cages must have 5x5 plates welded underrneath the bolt plates, then i THINK it is legal.. might wanan inquire tho...
Old Feb 21, 2003 | 11:12 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: roll cages (SIXTYdashONE)
also dont forget its 10.99@135mph. which most hondas going 10's are over 135mph. then you need a certified 10pt cage.
[Modified by MotorMatrix.com, 3:14 AM 2/22/2003]
Old Feb 22, 2003 | 02:02 AM
1fstcorrado's Avatar
way off 5 point min. for 11.99 and faster. 6x6 plates......here all correct info is in here>>>>> http://www.nhrasportcompact.com/2003/rules/index.html
Old Feb 22, 2003 | 05:48 AM
ekb18c's Avatar
Disregard the garbage inside the race car.
[Modified by ekb18c, 6:48 AM 2/22/2003]
Old Feb 22, 2003 | 06:04 AM
sickda6's Avatar
Default Re: roll cages (ekb18c)
no welding required... the rulebook says as long as you have 2 plates and 4 bolts for each point you are fine. welding the plates sucks anyway. i personally feel that 2 sets of plates and 4 grade 8 bolts are way stronger then welding 16 gauge plates to paper thin sheetmetal. if there was a roll, i think the bolt in system would hold better then welding. two plates arent going to rip through your floor, a welded plate could easily tear....
Old Feb 22, 2003 | 07:20 AM
eccentric.ek's Avatar
Default Re: roll cages (sickda6)
w0w nice tin work
Old Feb 22, 2003 | 09:15 AM
HT's Biggest Loser
Default Re: roll cages (1fstcorrado)
Huh?? so your telling me that you need a 5pt cage for 11.99?
Old Feb 22, 2003 | 09:24 AM
MySlowTeg's Avatar
yes a 5 point roll bar. that means a main loop (2 points) 2 bars going back to the frame (2 points) and a bar on the drivers side that goes down the side by the arm (1 point, can be bolted in place)
and the bars have to be welded together, but the mounting plates can be bolted in using 6x6 plates on each side.
promotor
May 9, 2009 11:18 PM
Hockey27925
Oct 5, 2005 06:45 PM
b18cx
Oct 30, 2003 08:33 PM
Backmarker
Feb 7, 2003 02:20 PM
Boostless97Lude
25
May 20, 2002 09:04 AM
