Roll bar legality question
Old Jul 21, 2005 | 04:47 PM
29psiHybrid's Avatar
Default Roll bar legality question
I am getting ready to install a roll bar in my 240sx (I know not a Honda but this is the best forum for this question) and was wondering if doing the back bars like in this picture would be NHRA/NDRA legal, with the cross bar connecting at the strut towers on 6x6 plates of course.
Old Jul 21, 2005 | 05:14 PM
Jared's Avatar
Default Re: Roll bar legality question (29psiHybrid)
You might want to look it up:
http://www.nhrasportcompact.co....html
but I'm pretty sure those rear downbars have to be welded to 6x6 plates of their own.
Old Jul 21, 2005 | 05:42 PM
boostedh22a's Avatar
I hope thats OK Robbie cause that is exactly how mine is done. Our local NHRA guy was at MR2 performance when Mike was welding in my bar and he said it was fine
Old Jul 21, 2005 | 05:56 PM
Default Re: (boostedh22a)
Thanks for the info guys, keep it coming!
Carey, got any pics?
Old Jul 21, 2005 | 06:08 PM
AllMoToRB18c's Avatar
Default Re: (29psiHybrid)
im pretty sure it will be ok...i seen a few cars that run bars like that due to have their rear floors cut out and havin no place to weld 6x6 plates to the floor so they run a set up just like the one u have pictured....u should be ok...double check though
Old Jul 21, 2005 | 06:16 PM
I got some pics on the indycarz forum. look under the build section I have a few pics there, just got the engine in this last weekend. Im getting stoked!!!
Old Jul 21, 2005 | 06:40 PM
Car is looking awesome man! Bemis gave me a run down of everything your doing, gonna be wild! Do you have any pics of the cage?
Old Jul 21, 2005 | 06:42 PM
I have a couple pics, what is your email I'll send them to you
Old Jul 21, 2005 | 06:43 PM
O yeah, thanks for the positive comments about my car.....it outta be fun. Your car sounds sick as hell. Already been in the low 11's....thats awesome....on street tires????
How much power are those rearends good for? I've been thinking about doing the RWD conversion on my Scooby??
Old Jul 21, 2005 | 06:48 PM
Thanks! That was on the new M/T street radials. People have pulled high 1.4 60's on stock axle and diff setups (lsd's of course). My email is t61civic@aol.com
Old Jul 21, 2005 | 06:51 PM
Thats some awesome 60's. I hoping for the 1.7's maybe 1.6's on my street tires???? Pics are coming
Old Jul 21, 2005 | 07:34 PM
I didn't 60' that btw lol. My best is a high 1.8 so far. Should be much lower next time out
Old Jul 21, 2005 | 07:35 PM
Yeah....1.80 has been my best so far
Old Jul 21, 2005 | 08:03 PM
SFWD 1934's Avatar
The rear bars are supposed to be welded to the frame rails. The tech inspectors will usually give you a hard time even if you weld them to the strut bars.
Then again depending on how tech inspectors are in your area, they may not say anything to you. But according to NHRA rules, to the rear frame rails.
Jason
Old Jul 21, 2005 | 11:54 PM
bigTom's Avatar
Default Re: (SFWD 1934)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SFWD 1934 &raquo;</TD></TR><TR><TD CLASS="quote">The rear bars are supposed to be welded to the frame rails. The tech inspectors will usually give you a hard time even if you weld them to the strut bars.
Jason</TD></TR></TABLE>
what if u cut the rear frame rails out
Old Jul 22, 2005 | 03:47 AM
They always seem to be a little more forgiving with full interior street cars
Old Jul 22, 2005 | 06:06 AM
My main reason for wanting to do it this way is I will easily be able to tip the cage back to get a good weld on top of the hoop and also the sides of my rear strut towers are nice and smooth so the plates would jive up nicely. I'll probly post pics once the install gets going.
Old Jul 22, 2005 | 07:04 AM
Pro-Am 1934's Avatar
Big Tom:
If the rear frame rail have been removed, then you are telling me, or at least I am understanding it this way: You have esentially back halved the car. If that is the case, then you will join together with the rest of the roll cage. Then you will bend the tube and weld it in place.
Jason
Old Jul 22, 2005 | 07:56 AM
old guy's Avatar
I checked with my sources at NHRA in Glendora, and the tech guys said they don't have a problem with your set up.
Old Jul 22, 2005 | 08:12 AM
bigTom's Avatar
Default Re: (Pro-Am 1934)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pro-Am 1934 &raquo;</TD></TR><TR><TD CLASS="quote">Big Tom:
i dont exactly understand what ur saying... but cutting frame rails or the floor out does not constitute a back-half
Old Jul 22, 2005 | 10:07 AM
PNG's Avatar
PNG
Default Re: (bigTom)
There are no "rear frame rails" in a unibody car, per the NHRA definition. That's why they specify that all the cage or bar attachment points have to have a 6x6 backing plate (or two, sandwiching the unibody, if it's bolted instead of welded). On cars with a true frame, the bars have to be welded or bolted directly to the frame rails.
We just put a bar into our project EK for an article in the September issue of OverRev. Steen Chassis did the work, and the diagonal back tubes are set up in exactly the same way as shown here - they tie in to a crossbar that extends between the two strut towers, and that crossbar is attached to the unibody on each end with welded 6x6 plates. If anybody knows how to build a safe and legal car, it's Gary Steen...
Old Jul 22, 2005 | 10:30 AM
bigTom's Avatar
Default Re: (PNG)
the 6x6 plates are not required for the bar linking the shock towers... at least thats what nhra tech has told me in the past...
i understand there are no "frame rails" by definition in a unibody... hence the "unibody." i was referring to the rails in the back of the car... whatever u want to call them
Old Jul 22, 2005 | 10:46 AM
tony1's Avatar
I did Arturbo's cage exactly like you're describing PNG. A 1.75 .083 crossbar welded to 6x6 plates on the strut towers, with the rear downbars connecting to this bar. It's passed tech a bunch of times, can't be too illegal! lol
tauumie
25
Jun 15, 2011 12:25 PM
SE_Owner
Feb 25, 2008 12:51 PM
130R
Jun 8, 2004 05:34 PM
itr_alexx
Sep 3, 2003 03:48 AM
