rim and slick question please help...
i wanted to buy slicks for a weld 15x8 size rim. Can anyone please tell me what size slick would be the best one for it and what brand (ie m&t, goodyear, hooser)
I should have about 350-400whp
for a 95 integra gsr turbo
website where i can purchase it from.
thanks in advance
thanks in advance
look into the 24.5x8.5x15 from M&H.
you can get them from MandHtires.com
That would be the proper size for the amount of HP you are making.
Just one question, why using 15" rim instead of a 13" rim
If you can use a 13" the 24.5x8.5x13 slick from M&H will hook up better since it has a taller side wall than a 15" rim More Bite for better hook up.
It depends more on the Slick itself. Each manufacturer will have a specification on what rim size each slick should go with.
Like most 13x8 will use a 7.5-8" rim. while a 9" wide slick will use an 8" wide as well. So you just have to check with what is recommended for that slick.
