Rev Limiter and Shifting
Old Sep 13, 2002 | 07:30 AM
89Si's Avatar
Default Rev Limiter and Shifting
I've gone down the track about 30 times in my just about bone stock 89 Si. So, when my car is warm, it revs up to right around 7200 rpm, but when its cold, I only get around 6800, and I look like a retard hitting the limiter when I'm going down the track. What gives? And I also hear that the motor has no power after 6500 or so... Have I been running far from my potential or what? Any help I could get with shifting at a good time would be good, considering I'm racing my friend for 50 bucks at the track next Wednesday.
WHEN SHOULD I SHIFT???
Old Sep 13, 2002 | 08:01 AM
Extreme's Avatar
Default Re: Rev Limiter and Shifting (89Si)
You are hitting the "cold", vs the higher "warm" rev limit and other ecu parameters.
You can find more specific information in the factory service manual.
Warm you car up before the run will help.
Try to keep you air intake cool though, cold air intake, cold damp towel on i/m, etc.
Shift point is based on drive style, power, traction, and other factors.
In other word, you'll have to experiment to achieve the best rpm point.
[Modified by Extreme, 5:04 PM 9/13/2002]
Old Sep 14, 2002 | 03:20 PM
zdr93523's Avatar
Default Re: Rev Limiter and Shifting (Extreme)
Usually the best place to shift is right at the rev limit, that's where you will be closer to your peak power after the shift
Old Sep 14, 2002 | 03:21 PM
azhatch's Avatar
Default Re: Rev Limiter and Shifting (zdr93523)
but what if you hit the limiter, and shift at the same time when the engine sort of cuts out, that would suck.
Old Sep 15, 2002 | 02:33 AM
H23 Power's Avatar
Default Re: Rev Limiter and Shifting (socalcivic)
yeah, any time you HIT the limiter it REALLY slows you down, even if you barely touch it
WillHam626
Honda Civic (2006 - 2015)
10
Nov 2, 2009 02:16 PM
black0hatch
Jan 18, 2008 09:20 AM
Jeremy D. Swain
Jul 28, 2005 01:31 PM
Tiwe
Dec 16, 2002 12:14 PM
USDM 4G VTEC
11
Aug 16, 2002 12:12 PM
