recent dyno
Old Jun 5, 2008 | 05:02 PM
phong's Avatar
Default recent dyno
This is B18C engine, GSR transmssion, 4th gear pull, 225 wide tires, 4 guys standing on the door sill to weigh the car down. The tires let loose at 7800rpm, 112mph. Still laid down nearly 838whp. If it maintain traction til redline (10,000rpm), by the way the graph look, easy low to mid 900s whp. We will retune the car on 235 drag radial and a bigger turbo housing soon. With more boost shooting for 1000+ whp.
[IMG][/IMG]
[IMG][/IMG]
Old Jun 5, 2008 | 05:06 PM
Garcia-Racing's Avatar
Awesome
Old Jun 5, 2008 | 05:08 PM
streetracer6rpt's Avatar
Default Re: recent dyno (phong)
Old Jun 5, 2008 | 05:44 PM
speeddave's Avatar
Default Re: recent dyno (streetracer6rpt)
insane
what's the motor setup and fuel? (if you dont mind me asking)
Old Jun 5, 2008 | 05:52 PM
Kevin's Avatar
Default Re: recent dyno (speeddave)
clean install...got anymore pics?
Old Jun 5, 2008 | 05:53 PM
SovXietday's Avatar
Wow, that looks like all off the shelf parts too.
Old Jun 5, 2008 | 06:04 PM
jdm inc's Avatar
that sick as hell
Old Jun 5, 2008 | 06:12 PM
b00stedbyFastrax's Avatar
wow! how much boost and turbine size?
Old Jun 5, 2008 | 06:31 PM
SpeedDreamz.com's Avatar
how is the car after the 1-2-1 shift?
Old Jun 5, 2008 | 06:33 PM
mikesrex's Avatar
looks good man!
Old Jun 5, 2008 | 06:53 PM
boosted k20's Avatar
Default Re: (mikesrex)
Nice. specs?
Old Jun 5, 2008 | 06:58 PM
cotorresgee's Avatar
good job
Old Jun 5, 2008 | 07:33 PM
phong's Avatar
Default Re: recent dyno (b00stedbyFastrax)
85mm B18C
stock port head
ITR cams
stock distributor
BW S372 standard cover 1.10 exh
Hondata S300
Boost was at 40.6psi and drop to around 38psi by redline due to the 1.10 exhaust housing. We will test out the new R cover with the 1.25 exhaust housing sometime in the coming weeks. Yes the motor is still ok (i hope) after the 1-2-1 shift at Texas Tuner Showdown last week. We got a new set of rod bolts on order already.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Modified by phong at 8:59 PM 6/5/2008
Old Jun 5, 2008 | 07:51 PM
MeanGreenMachine's Avatar
wow! a stock ignition.....how did u manage to make this much power on a stock ignition?
Old Jun 5, 2008 | 07:56 PM
Hondatron's Avatar
Was the car tuned on Hondata? Sick numbers, never thought a stock port head would be taken this far in this type(gas) of car
Old Jun 5, 2008 | 08:57 PM
H.A.R.T B18C1EG6's Avatar
Default Re: recent dyno (Hondatron)
wow
Old Jun 5, 2008 | 09:02 PM
BoostedJeff's Avatar
Default Re: recent dyno (H.A.R.T B18C1EG6)
Very Nice! Bullseye
Old Jun 5, 2008 | 09:57 PM
FastEg6's Avatar
Awesome power, clean setup also. Do I see a stock CD player in there?
Old Jun 5, 2008 | 10:28 PM
alopez84's Avatar
Looks good Phong, keep it up!
Old Jun 6, 2008 | 12:00 AM
V-SPEC 1's Avatar
Default Re: (alopez84)
that's insane power.
Old Jun 6, 2008 | 12:03 AM
PremierS372's Avatar
Default Re: (V-SPEC 1)
sick power
Old Jun 6, 2008 | 04:18 AM
SPOOLINmatt's Avatar
Default Re: recent dyno (MeanGreenMachine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MeanGreenMachine &raquo;</TD></TR><TR><TD CLASS="quote">wow! a stock ignition.....how did u manage to make this much power on a stock ignition?
ya rly?
Old Jun 6, 2008 | 04:42 AM
Turbocivic94's Avatar
Default Re: recent dyno (SPOOLINmatt)
Thats called pushing the envelope
Old Jun 6, 2008 | 06:05 AM
roadracer4life's Avatar
now i know why you said you were having traction issues in 3rd and 4th gear... WOW pretty impressive..
what kind of clutch do you have holding all that in...
Modified by roadracer4life at 10:35 AM 6/6/2008
Old Jun 6, 2008 | 06:36 AM
HondamanXxX's Avatar
GO GIANTS!
Default Re: (roadracer4life)
That is such a simple empty engine bay that makes a lot of power, I love it.
