Racing...now a trans problem
Old Aug 17, 2009 | 06:53 PM
SpoolnG2's Avatar
Default Racing...now a trans problem
Since you guys know so much about transmissions i figured I would see if you could answer a quick questions before i take everything appart. I have a b-series motor/trans. Turbo charged on slicks and recently put a stage 4 CC in, resurfaced the flywheel, along with a new pilot and throw off bearing. Broke it in for 3-400 miles. Was at the track, launched the car about 4 times and then on the 5th run for some reason i missed second gear. I continued the run and got it into 3rd and 4th with no problems. After I slowed down and and went to put it back in first i noticed what sounded like a grinding noise. If the car is just sitting there and i push the clutch in, just letting it out the slightest bit allows me to hear the grinding type noise, but No where near the actual engagement point of the clutch. What does this sound like to you guys? If i let it all the way out the clutch does engage and i can technically drive it. Just curious what this sounds like it might be?
TIA
Old Aug 17, 2009 | 06:56 PM
boosted91crx's Avatar
Default Re: Racing...now a trans problem
hmm to vague to be sure, your best bet is to take it out and look and see.
Old Aug 17, 2009 | 07:09 PM
Garage 808 Hatch's Avatar
sounds like an input shaft bearing going bad to me
Old Aug 17, 2009 | 07:34 PM
SpoolnG2's Avatar
I'm def gonna rip it appart Thursday...just looking for some possibilites is all. I was thinking internal since I just replaced everything external but I'm not too familiar with the internals of transmissions in general.
Old Aug 18, 2009 | 03:11 AM
90teg's Avatar
It sounds like your clutch won't let you shift. Same thing happened to me 3 times. Once with a stage 4 and twice with a stage 5. And all that's changed was your clutch and flywheel? If so get something other then a CC clutch this time.
Old Aug 18, 2009 | 03:56 AM
ALL IMPORT's Avatar
could be u broke a few teeth on the ring gear or maybe even the countershaft gear. its very hard to tell their are alot of parts. u can break 1 tooth on second & it destroy the whole trans.
tico
Jun 23, 2010 08:20 AM
CuteAccord
Feb 1, 2010 03:39 PM
SpoolnG2
Transmission & Drivetrain
Aug 18, 2009 04:59 PM
AL ASPIRATED
Oct 30, 2003 04:06 PM
01-0720
Oct 10, 2003 10:34 AM
