Question about spool install
Old Aug 2, 2003 | 05:41 PM
275Performance's Avatar
Default Question about drag spool install shims
I am about to install a TCI spool in an LS tranny. Will I need the been a need to use other sized shim's with this install , same as you would in some Quaiffe installs?
Thanks.
Modified by 275Performance at 8:57 PM 8/2/2003
Old Aug 2, 2003 | 06:33 PM
compact-tuner's Avatar
Default Re: Question about drag spool install shims (275Performance)
hey bud and do your self a favor.look pretty hard at the spool and make sure there is the clip notch cut into the splines and that the splines dont go clear to the outer edge.
i have a tci spool,i was not watching what i was doing,installed it and the noticed that the axles would not go in all of the way because the splines were out to the edge and it did not have a clip groove.as for the shim it will be different,so make sure you shim it to spec.all different thickness shims are availabe through honda.
i hope i saved you any headache.
brian jenkins
sangamon valley racing
ndra pro 4 cyl #8434
Old Aug 2, 2003 | 06:42 PM
Default Re: Question about drag spool install shims (compact-tuner)
Thanks a lot for the advice. I'll look at it tonight. What did you end up doing since the clip groove was not there?
Old Aug 2, 2003 | 06:45 PM
i got a buddy at a local machine shop.he cut it for me and counterbored the splines so the axles would fit.i contacted tci and they were not aware of the problem at that time.
good luck
brian jenkins
Old Aug 2, 2003 | 07:13 PM
I just looked at it. The spines are receased in about an inch on both side, and there is 1 clip notch about 1 inch in fron the end of the splines closer to the gear side.
turbo gsr
Sep 20, 2005 07:22 AM
Shadowhunter
Sep 2, 2005 11:51 AM
DeLiRiOu5
Honda Motorcycles
Jul 4, 2005 03:54 AM
